Old 04-28-2005, 04:31 PM
B Schein's Avatar
B Schein B Schein is offline
Default Another set back
I just got done with modifying my firewall and trany tunnel to accommodate my engine set back. I am not sure on the final numbers as to how much the motor is set back over stock because I have nothing to reference stock location relative to mine I just moved it back far enough for the balancer to clear the rack mount with a little room to spare.
I am just wondering what every one else has for set back if any.
Brian
Old 04-28-2005, 05:09 PM
68protouring454's Avatar
Default brian
looks awesome, killer work, i think tyler and phase shifts set backs are around 6 inches, and look to be similer to yours, are those c5 or sed spindles??
what rear suspension are you fabbing?
jake
Old 04-28-2005, 05:19 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Looking good, Brian. Is that a wheelbarrow ala Banks?
My LS7 69 Camaro
Old 04-28-2005, 06:06 PM
B Schein's Avatar
Good eye Scott it is a wheelbarrow. I actually got the idea from Wayne Due when I was talking to him about Tyler’s car. His made the same way as mine. It must be split in half and widened about 4 inches to be wide enough for the motor to fit in side. I am sure that they had to due the same thing on the banks car but speed lefever is a better sheet metal guy than I am so you cant see where it is widen, but on mine you can.
As for the spindles I made them as well as the rest of the frame, they are the JPIFS spindles. The rear will be a three link. My car is basically the camaro version of II Much minus the perimeter frame it has all the same suspension.
Brian
Old 04-28-2005, 09:15 PM
almcbri's Avatar
almcbri almcbri is offline
great work! that firewall looks killer
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 04-28-2005, 09:24 PM
Good job Brian. Besides a real clean look and solving a clearance issue you get another good weight balance improvement.
Old 01-05-2006, 12:55 PM
rwhite692's Avatar
That is really neat, very resourceful.
Project update thread here:
My Lateral-G Page
My Shop Build:
