Old 12-10-2005, 10:28 PM
4OfaKind's Avatar
4OfaKind 4OfaKind is offline
I was looking at your project pretty sweet why are you using that rack the olds Brvada came with a rack, the streeing shaft is relocated to the middle of the diff case. But if you must use that rack the steering shaft must come stright up to the upper frame rails the over with bearing-style steering universal joint with splined rack adapter joints and rod ends to support the steering shaft with the custom fenderwell you will keep it clean under the hood you might have to use a under dash master cyclinder with a 90 drake padals.what is the ride height? and you know that all 4 tires size must be the same height.
I chose this rack for the low number of turns from lock to lock. I thought I would have to go over the diff, but the mount and tubing appears to be in the way. Do you think it would be possible to rotate the rack and run the steering shafts under the diff? Ride height is maxed at 5" front and 6" rear. The coilovers will be adjustable down to 4" front and 5" rear. No room for air bags.
im working on a brake booster mount for tri-5's right now, it relocates the brake booster outboard and up, so that it actually tucks up under the driverside fender, obviously it wont work with factory inner fenders, but with that much fab work...i doubt a set of custom fenderwells is outa the question.
Brakes are next on the list. I am planning 14" front and rear rotors w/ 4 piston calipers each. Race I have been contemplating an offset MC w/ a balance bar between it and the pedal. I really want an under floor mount but I doubt there will be room for it. We will see.
Mal
Old 12-10-2005, 10:32 PM
4OfaKind's Avatar
Too bad you'll have to cover all the fab work up with a body.
Oh I dont know X. I think we will be singing a different tune once the body mods are complete.
Mal
Old 12-11-2005, 06:09 AM
hotwheels's Avatar
hotwheels hotwheels is offline
very nice set up and welcome to lateral-g, officially.......
1992 mustang gt twinturbo'd
1988 mustang gt bottlefed
2004 mach 1 resting in garage
1989 mustang coupe 4 cyl.
1980 mustang coupe 4 cyl.
MY MUSTANG ENTHUSIASTS SITE
Insanemustangs
Old 12-11-2005, 06:46 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Mal
Cool, I'm looking forward to it.
My LS7 69 Camaro
Old 12-27-2005, 05:10 PM
clinthart's Avatar
clinthart clinthart is offline
Wow... that is some awesome work going on there. Best of luck.
Lets see Chip Foose do that in 7 days.
LOL
Old 05-19-2006, 12:41 PM
4OfaKind's Avatar
Thumbs up Collecting parts
This week my frame was delivered. Long story short; thankfully no one wanted it when I was trying to sell it and I was able work something out to keep it.
Additionally, I bought some corvette z06 rims 17x9.5 front and 18x10.5 rear to use as rollers and mock up the proper sizes for a set of custom billets. I also bought a 350ci 4 bolt main block. This will be stroked to 400ci after I use it to mock up the engine mounts.
Pictures should be available tomorrow.
Mal
Old 05-19-2006, 04:22 PM
4OfaKind's Avatar
Here are the pics as promised. My garage is a little small. You can see the block in the back.
Mal
