Old 07-12-2010, 05:36 PM
cluxford cluxford is offline
Default Flush mounted glass what are you doing for seals ?
As the title suggests curious to see what brands those who have flush mount front and rear screens are using.
I have welded a bead inside the frames and will seal with sealant / glue to the frame, but then need to run the rubber seal on the outside to tidy it up, can anyone share what / where they got a rubber seal to fit
Thanks in advance
68 Camaro 632 BBC 800+ HP Project (600Kw)
61 Buick Lesabre Bubbletop (daily driver)......miles of smiles
Old 07-12-2010, 06:56 PM
prostreet69cama's Avatar
prostreet69cama prostreet69cama is offline
Are you using stock glass or the oversize glass? I just installed the glass kit from Glass Innovations. I think that is what the company is called.
It was a pain making there rubbers work that came in the kit but it turned out nice.
I would do it different on the next car.
Go here and you will see some pictures of it.
http://www.camaros.net/forums/showthread.php?t=146850
Old 07-12-2010, 07:53 PM
Thanks, yeah standard glass, welded a bead into the frame to remove the gap from the chrome trim...
Old 07-13-2010, 08:06 AM
How much of a gap did you leave between the glass and body. I would make it look like the truck flush glass. They have a rubber that slips on the side of the glass and when you set the glass it will fill the area between the glass edge and body. Like the new cars .
Here is the type we used that came in the kit. This is the small one and we used the next size. Sorry dont have a piece that we used. The hardest part is going around the curves.
Old 07-13-2010, 09:50 AM
Finch Finch is offline
I use a J-channel molding for the flush mount glass kits. It has an adhesive in the channel where it attachs to the glass and comes in multiple widths up to 1 inch. It is much easier to work with vs. what comes in the flush mount glass kit.
Old 07-13-2010, 10:28 AM
elitecustombody's Avatar
I use universal molding that comes on big rolls from Safelite, call your local Safelite glass distributor,they sell all the materials you need for glass installation
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 07-13-2010, 03:54 PM
Thanks everyone, that's perfect, exactly what I was after...
Old 07-14-2010, 09:44 AM
I will make it easy for you if you want to buy online.
http://bondsbrothers.com/products.asp?cat=68
I buy the FT2030-75 and the FT1830-75
Old 07-14-2010, 12:02 PM
How does this rubber fit around the corners,,does it curl up. I tried the wider rubber 3/4" and had hell around the curves. It wanted to wrinkle up and not lay flat. Do you have pictures of it installed? Did you have to "V" cut the back side to make it fit?
Old 07-14-2010, 01:32 PM
I have not had any issues with curves. Key thing is to tape the entire molding down with blue or green painters tape overnight to let everything set. On actual corners I cut the molding to make a 45.
