Old 02-17-2011, 11:12 AM
Default Anybody running a backseat with a Quadralink?
Admittedly I was torn as to whether this should be in interior or suspension section .
Initially I thought the DSE Quadralink would preclude me from having a backseat. Then I happen to notice that DSE says you can still run one. I can't remember seeing anybody with that setup though. The builds here that I'm aware of don't have backseats. Anybody running Quadralink and a backseat? What mods to the seat frame are necessary?
The G-link was at top of my list for this reason. However, I think the Quadralink has the advantage when it comes to routing large exhaust pipes up over the axle.
Thanks,
John
John
'71 Nova (Build thread)
FFR Roadster
Old 02-17-2011, 01:34 PM
slenning's Avatar
slenning slenning is offline
You can definately have a back seat with a Quadralink. I had to narrow the seat frames 3" I believe for the mini tubs and had to notch a little under the seat frame for the upper pockets.
Uploaded with ImageShack.us
Steve
70 Camaro - in process https://lateral-g.net/forums/showthread.php4?t=50636
69 Camaro LS7/T56 https://lateral-g.net/members/lenning/
69 Camaro SS396/350hp
64 Chevelle - patiently waiting
2014 Z28 Ashen Gray
2010 Camaro 2SS/RS Black w/White stripes (wife's car)
2015 SS (the 4 door one) Wife's other car
Old 02-17-2011, 01:55 PM
6spdcamaro 6spdcamaro is offline
I just finished modifying the back seat frame to fit with the Quadra-link and mini tubs. All that is necessary for the Q-link, is a few small wires near the upper four link brackets need to be cut a re-routed. The minitubs are a little more involved. Its not a difficult job to do, just a little tedious.
Ken
Old 02-18-2011, 05:54 AM
Thanks guys. Good to know it is possible. Hopefully the same applies if it is used in a Nova
John
FFR Roadster
Old 02-18-2011, 08:29 AM
BBC69Camaro's Avatar
For narrowing the seat after a mini-tub you might check out:
Mini Tub Rear Seat Narrowing
https://lateral-g.net/forums/showthread.php4?t=28606
Old 02-22-2011, 06:30 PM
Jon Clough's Avatar
Jon Clough Jon Clough is offline
That is the best rear suspension IMHO, even if you have to cut a little off the seat.
Old 02-23-2011, 07:04 AM
rchaskin's Avatar
rchaskin rchaskin is offline
Also look on the DSE website under DSE Projects.
Look at the DSE 1969 Test Car.
It shows how they cut the seat frame around the QL brackets.
Good luck.
