Old 06-19-2011, 06:08 PM
Originally Posted by jasond26 View Post
yeah is has the JP performance double roller 4x timing chain and 58x reluctor wheel on the crank
when you figure it out let us know. And good luck!
Old 06-19-2011, 06:26 PM
jasond26 jasond26 is offline
Thanks for all your help, I am going to give them a call tomorrow to see what the fix action is going to be. I will keep you guys posted.
Old 06-20-2011, 10:30 AM
Rybar's Avatar
Rybar Rybar is offline
Good luck getting through to them. My buddy's tuner figured it out PM me if you want his number he may know the password.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 06-20-2011, 05:11 PM
I ended up getting the password but the changes didn't help. Is still does not start. I have tried everything I can think of. It is getting cam signal and crank signal. No spark. I will go over the grounds again and check through it one more time.
Old 06-20-2011, 05:33 PM
how long have you cranked it without getting a spark?
Old 08-19-2011, 08:56 PM
TurboNova's Avatar
TurboNova TurboNova is offline
I am bringing this up because I have been having an issue with my BS3. Brand new lsx motor and it will not start. Using the BAL feature I never get cam crank sync. I have tried everything, shooting voltage, new sensors. I have stumbled accross this thread and looked at the dealer settings, turns out the cam signal is set for none. It needs to be 5v. Does anyone have the password so I can fix this and get it running. Thanks.
I believe it's "engine"
you will have to key off and disconnect the battery after doing so. This will store the changes.
For the LS engines, they are hall effect pickups so they both should be HED according to the Dealer manual.
None of the other settings are needed for the LS setting.
If you choose "other" then, you need to choose rising or falling. Your input to the sensor is 12v because one side of the sensor has 12v in.
IPU is inductive like MSD type ignition.
Sad when the dealers can't even sell stuff setup for the customer. This is a basic one along with the first post in the thread.
Brian Macy
Instructor
EFI University
www.efi101.com
owner
Horsepower Connection.com
Fuel Injection Dyno Tuning Turbocharging
cell 360-280-6112
