Old 03-15-2006, 04:00 PM
bwindy bwindy is offline
Default When to upgrade big block internals
What is your opinion on when to upgrade the crank and rods in a big block Chevrolet (1975 454). In other words how much power can a stock crank handle and the same for rods. Is anyone running a 700 hp engine with a stock rotating assembly with success. I do not want to have an expensive crank and rods just to say that I have them. Thanks
Old 03-15-2006, 06:11 PM
*rayman*'s Avatar
*rayman* *rayman* is offline
i'd also like to know some details on this.
68 BB SS Camaro - building it in Australia, where everything costs twice as much as it costs in the U.S.
Fuel prices suck!
Old 03-16-2006, 08:15 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
I guess it's up to someones opinion, what they want to risk, and what type of rpm's you'll be running.
I was recently reading a "How to Build BB Power", or something like that, and it states a cast crank and 2 bolt block can handle 600 hp. After just recently tearing down a 454 with a cast crank and 2 bolt block, I'd tend to believe that, or more. The journals on the crank are huge, and the main caps are very large to. A two bolt bbc should never be compared to a two bolt sbc, those main caps are puny to say the least.
I'd guess if you added splayed main caps to a 454, and run a forged crank, you could probably through just about anything at it.
You could ask over here, http://speedtalk.com/forum/index.php
There are some real engine guru's over there, .
