Old 08-28-2012, 10:13 PM
aany001's Avatar
aany001 aany001 is offline
Default Stainless brake line
Where can I find a roll of 3/16 and 1/4 stainless brake line and fittings? what is everyone using for brake lines? Thanks guys
Old 08-28-2012, 10:26 PM
Stainless line usually comes in straight lengths. It's tough to bend, if it was in a roll it'd be near impossible to get straight again.
I've always bought mine locally at the places I get my AN fittings. Inline Tubes sells it also, but not sure what shipping does; it would definitely limit the length.
Old 08-28-2012, 10:52 PM
aany001's Avatar
so what should I use? use standard line then paint them somehow? I never worked with stainless before.
Old 08-28-2012, 11:10 PM
snappytravis's Avatar
snappytravis snappytravis is offline
someone said copper nickel I think is easier to work with,
Old 08-29-2012, 12:08 AM
Definitely easier to work with and its supposed to be pretty corrosion proof.
Old 08-29-2012, 12:46 AM
Sieg's Avatar
Sieg Sieg is offline
I used copper-nickel and lightly buffed it with 000 steel wool. 25' Coil lengths and very easy to work with.
You can also buy stainless tubing from Summit in coil lengths. You'll probably want/need a tubing straightener with the stainless.
Old 08-29-2012, 03:07 AM
Chevy Kid Chevy Kid is offline
You can buy stainless tube and fittings from Eastwood also...
Old 08-29-2012, 11:19 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
check these guys out and read the tech clip at the bottom of the page. specifically the one about flaring stainless tubing.
http://www.inlinetube.com/
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
