Old 05-23-2006, 12:37 AM
mazspeed's Avatar
mazspeed mazspeed is offline
Originally Posted by rocketman
well I have a new ls7 crate motor,but I also have a tall deck donavon block too.so I haven't decided.
Give me one
Old 05-29-2006, 02:28 PM
USAZR1's Avatar
USAZR1 USAZR1 is offline
Originally Posted by XcYZ
That's the same block that I'm using. It fits under the stock cowl hood no problem, but getting headers to fit is a challenge.
Scott,I'm kicking around the idea of building a 427 sbc with a Dart Iron Eagle tall deck block. Tell me more about your header fitment problems. I would like to keep my Hedman headers,if possible.
Clint Hooper
Clint's 70 El Camino restomod Sold
Clint's 69 Elky Protourer Sold
Old 05-29-2006, 06:21 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Clint, I was using a set of Hooker Super Comps and the issues I had were:
1. the #1 primary hitting the pitman arm retaining nut
2. clearance for the upper control arm mount bolt
3. the collector on the right side touching the floorpan (because it was indexed differently than the left side)
4. couldn't run a 3" air cleaner (but I was also running a tall single plane)
All the fixes were pretty easy, it was a matter of 'massaging' the headers and running a K&N X-stream lid. Another thing to keep in mind about the Iron Eagle tall deck is that since the pan rails are spread .800", there's no provision for oil filter built into the block, you have to run a remote oil filter. No biggie, though.
My LS7 69 Camaro
Old 05-30-2006, 02:29 PM
USAZR1's Avatar
My car has a 3" Glasstek cowl hood so I hopefully wouldn't have any intake clearance problems. Would probably run the Dart tall deck single plane,though. Running a remote oil filter would be easy but I'm wondering if that block has provisions for my manual trans Z-bar. Not interested in having to convert to a hydraulic clutch set-up.
Clint Hooper
Old 05-30-2006, 05:51 PM
XcYZ's Avatar
It will definitely fit under your hood. I have that intake and I'm 99% sure I won't be using it with the turbo setup, so if you're interested in it down the road, let me know.
The boss is in the block for the clutch Z-bar pivot, it just has to be tapped. I used the stock linkage with my 434 and the TKO and it worked great.
My LS7 69 Camaro
Old 05-31-2006, 07:20 PM
USAZR1's Avatar
I'll keep you in mind on that Dart intake,Scott. Thanks.
Clint Hooper
