Old 02-01-2015, 01:26 PM
formula88's Avatar
formula88 formula88 is offline
Default Hellfire in CARS Inc 2015 Calendar
Hellfire, as a work in progress, is featured in the 2015 CARS Inc. calendar for the month of February.
Gordon
Old 02-06-2015, 12:04 PM
MAP MAP is offline
The conundrum we always face with these technical interchanges is that only discussions within a broad public-domain definition can be occur. As soon as we get into something that's truly technically intriguing, IP corporate concerns shut down any further discourse. (The dark side of engineering that they never told us about at MIT.)
If I'm right about this, then we won't be hearing back from Mark in this thread again. Of course, I hope I'm wrong about this.
Best,
MAP
Old 02-06-2015, 12:10 PM
frojoe's Avatar
frojoe frojoe is offline
Maybe this thread pretty quickly went in a massively-wayward and obscurely technical direction, hence the silence from Mark, since he's likely moved on to 1 or 2 other new main/side projects....
Just a thought.
Joe
1972 Nova with twin 6466's and T56 Magnum in the works. Speedtech, Ridetech, Wilwoods etc. Swap thread --> http://ls1tech.com/forums/showthread.php?t=980909
Old 02-06-2015, 12:31 PM
Roberts68 Roberts68 is offline
Just a thought.
Best,
MAP
MAP, you might start a new thread in an appropriate subforum for your discussion, see what develops.
If it feels like the tangents you present are worthy of in depth discussion yet detract from a thread... Or drive off the original poster then that is likely the case and worthy of reconsidering.
That doesn't necessarily mean they won't be welcome discussions in their own right.
Old 02-06-2015, 01:50 PM
MAP MAP is offline
Thanks,
Too bad I can't go back in time and un-do those posts because it was never my intention to derail this thread - in fact, quite the opposite - the intention was to help drive it forward. Apologies again to Mark and everyone for having inadvertently done so. In retrospect, in our company too, it's lockdown mode when someone outside ventures into IP...
However, maybe in some small way those posts will stimulate thought for progress.
Best,
MAP
Old 02-06-2015, 02:55 PM
Stielow's Avatar
Stielow Stielow is offline
Thanks,
Best,
MAP
MAP
A mid engine car would be faster. If I put my engine in a AWD mid engine car it would be faster. If I put my engine in a ZR-1 it would be faster. Just simple physics.
New or mid engine cars have better areo, CG, weight distribution.....
I'm not sure what question your asking.
Mark
Old 02-06-2015, 03:46 PM
syborg tt's Avatar
Hi Mark,
Okay since where talking all this stuff that is way over my knowledge base. What are you thoughts on the new front wheel drive race car that just built and are taking to Le Mans.
http://www.autoblog.com/2015/02/02/n...-wec-official/
ps - Sorry for the Thread Hi-Jack
marty-mj
Old 02-06-2015, 03:51 PM
Stielow's Avatar
Hi Mark,
They did a good job the reading the rule book.
Old 02-06-2015, 07:14 PM
dontlifttoshift's Avatar
Mark, where did you hide the GPS antenna for the Dash2? Did you have any problems getting GPS lock with that location?
Thanks!
Donny
Old 02-06-2015, 10:54 PM
MAP MAP is offline
Mark,
I'm very relieved and pleased to see that I was in fact wrong. I wasn't really asking any question, but just suggesting, by highlighting the physics, that given all of the ambitious and impressive things you've already done with Camaros, that rather than switch to a platform better suited to mid-engine, you might in fact try the close-to-impossible and make a 1st-gen Camaro that's mid-engine.
Thanks,
MAP
