Old 03-14-2016, 07:01 PM
jeff71 jeff71 is offline
dup post
Old 03-14-2016, 07:03 PM
With the frame rail replacement you used two piece not one? Would it have been better to make out of one? I ask because I'm in a similar situation with my fastback, I have a DSE Aluma-frame also. Any suggestions?
Originally Posted by GPR View Post
The floor pan had to be replaced
Brushed epoxy
Installed torque boxes
Test fitting
Installing DSE subframe connectors
Both front frame rails had a little rust
We are waiting for the DSE rear suspension
Old 03-14-2016, 07:05 PM
Heres mine.
Passenger side...
Drivers...
Old 03-15-2016, 05:50 AM
GPR's Avatar
GPR GPR is offline
Brian did not replace the frame rail only cut out the rust and made a patch. On yours it looks like you have a lot of rust and I would replace.
Rusty Gillis
Gillis Performance Restorations
Port Richey Fl
www.gillisrestorations.com
