Old 10-19-2023, 12:09 PM
fleet's Avatar
fleet fleet is offline
The Following User Says Thank You to fleet For This Useful Post:
syborg tt (10-20-2023)
  #2302
Old 10-19-2023, 01:02 PM
dontlifttoshift's Avatar
Hi Donny,
All of the bolts are tight and the brackets can't swivel. However, since the brackets are so close together I need to put a
washer behind one of them so the brackets can be flat. In the rare occasion that I have a passenger in the back seat I was
worried about them bumping the bracket. On a side note you will have to be one hell of a contortionist to get back there.
Here is a side shot of what it looks like and I am open to your advice as I this is all new to me.
Thanks for the side pic. That is all wrong and it will never be perfect but it can be better.
Turn the harness bar around so the welded tabs are on the back side but still pointed down. Then bolt the harnesses on the back side. I would consider bolting them on with the angle going forward even, assuming it will fit that way.
Side bar. Nobody you like should be sitting in that back seat with that harness bar there.
Donny
The Following User Says Thank You to dontlifttoshift For This Useful Post:
syborg tt (10-19-2023)
  #2303
Old 10-19-2023, 05:53 PM
Cramer4918's Avatar
Definitely and exciting day, Marty! I'm happy for you! It looks great rolling down the driveway on it's own power!
-Matt-
'61 Biscayne ~ AKA BISKWIK
The Following User Says Thank You to Cramer4918 For This Useful Post:
  #2304
Old 10-20-2023, 04:26 AM
Hotwire Hotwire is offline
CONGRATS MARTY!!!!
Next time you need to fill up the cooling system on an LS, keep the top hose loose and fill from it, it will ensure you get the entire block full with hardly any air left in the system. It also bypasses the thermostat so filling is much quicker. Basically the same idea as pulling the thermostat housing from a SBC/BBC and filling the cooling system from the thermostat hole in the intake. Makes a huge difference in the end.
Get some smiles per mile son, you deserve it!!
*Jeff*
Project Salty - 1964 4 door Malibu, beaten, neglected, red headed foster child
Cammed LQ4 / T56 Swap Project Thread <-click to read! 😁
The Following User Says Thank You to Hotwire For This Useful Post:
  #2305
Old 10-20-2023, 07:45 AM
syborg tt's Avatar
Morning Donny,
I will flip it around this weekend and thank you for catching this I really appreciate it.
ps I looked back at old pictures and it was on the way you explained.
Thank you Matt I can't tell you how happy I was to get it out of the garage.
Hi Jeff,
Funny thing I was going to call you the other day to see how you were doing and I will give that a try next time.
Originally Posted by Hotwire View Post
CONGRATS MARTY!!!!
Next time need to fill up the cooling system on an LS, keep the top hose loose and fill from it, it will ensure you get the entire block full with hardly any air left in the system. It also bypasses the thermostat so filling is much quicker. Basically the same idea as pulling the thermostat housing from a SBC/BBC and filling the cooling system from the thermostat housing in the intake. Makes a huge difference in the end.
marty-mj
Hotwire (11-16-2023)
  #2306
Old 11-12-2023, 03:11 PM
Cramer4918's Avatar
Well...... Have you put any miles on it, Marty?
-Matt-
syborg tt (11-16-2023)
  #2307
Old 11-14-2023, 05:11 AM
jarhead's Avatar
jarhead jarhead is offline
Awesome!
joe
Semper Fi
My 68 Torino
The Following User Says Thank You to jarhead For This Useful Post:
  #2308
Old 11-16-2023, 07:37 AM
syborg tt's Avatar
Not many as I have had so much going on the last couple weeks. Hopefully next week I will be back on the car after work.
ps I have gone out and done small things when I can find an hour here or there.
marty-mj
The Following 3 Users Say Thank You to syborg tt For This Useful Post:
camcojb (11-16-2023), Cramer4918 (11-17-2023), Roscoe03 (11-17-2023)
  #2309
Old 11-16-2023, 01:13 PM
syborg tt's Avatar
Default Post Sema Fatigue (( 11-04-23 ))
Rule #1 Don't go to Sema when you are building a car that may or may not go back to Sema. Why, Because you are going to see some really cool stuff.
Like this.
and this, Yes I am going to get a hold of the guys at TechFlex and order some of the red/back wire sleeve.
marty-mj
jarhead (11-24-2023)
  #2310
Old 11-16-2023, 01:20 PM
syborg tt's Avatar
Default The little Stuff (( 11-08-23 ))
I am pretty sure it was Mark that said this. If you have an hour to spare head out and do one of the small projects. So, I installed
a Burn Out Switch to prevent my friends from doing a burn out when I am not around.
Cleaning up the Fuel Pump wiring.
I still need to finish the taillight wires.
Pitman Arm Nut replacement.
I also ordered Scissors so I can trim the carpet.
Original Nut - Kinda Ugly
Much Better (( 11-11-23 ))
marty-mj
camcojb (11-16-2023), Roscoe03 (11-17-2023)
