I have a booster on my car right now and it seems like it just kills the engine conpartment. Do I really need to run one? I have 13s in the front and 12s on the back
I think The engine conpartment would look alot better without it.
If you're going to run manual brakes, then I think you should look at running twin master cylinders with a balance bar. Payton has a trick setup in his 69, maybe he can post a picture.
I had Jim Pettigrew make this up for me. The set-up uses stock pedals and mount and he modified one pedal and the mounting bracket. I did have to cut 2 new holes for the masters to go through. These are not the best pics in the world, so if you want to see something specific just let me know and i will take more.
you can run no booster if your pedal in your car is for a manual brake car. The pedal ratio needs to be correct or your brakes will feel odd and not work properly.
