Old 09-13-2007, 08:44 PM
69 Pilot 69 Pilot is offline
Default Flywheel Part #
I know this question has been answered before but can someone tell me the part # for Mcleod flywheel for two piece rear, pull style T/O bearing for an
LT1 T56 to gen 1 swap
Old 09-14-2007, 07:17 AM
jsr69's Avatar
jsr69 jsr69 is offline
Looking through my notes, I have No. 460370 wrote down. Hope that helps.
Steve Spoor
69 Rally Sport with Quadra-Link, Wayne Due C-4 Subframe, T-56, 420 SB2.2
67 Chevelle, Art Morrison Chassis, 416 LS3, T-56 (under construction)
Old 09-14-2007, 07:15 PM
thanks!
Old 10-13-2007, 02:35 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Conversion p/n's.
460370 shows for a one piece rear main engine. 25lb.
460300 is for a two piece rear main, internally balanced engine. 30lb.
460300-2C , ditto, externally balanced. 30lb.
700107 is the Centerforce flywheel, 2 piece, internal. 29.3 lb.
2555 Ram, ditto, ditto. But aluminum. 18lb.
Double check with manufacturer before ordering.
Old 10-14-2007, 08:58 AM
Btw.. are those Gm performace crate small blocks( like ZZ4? ) externally or internally balanced ??
63 Z06
Old 10-14-2007, 05:27 PM
MarkM66's Avatar
All sbc except the 400 is internally balanced.
