Old 11-22-2009, 04:43 PM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
Default Axle Brake Line Clamps
I have 12 sets of these brake line clamps!
Originally Posted by Gonzo View Post
Here is a pic of the axle tube clamps.
Old 11-23-2009, 01:37 PM
syborg tt's Avatar
Send me your payment info and I'll send you money as promised
[email protected]
marty-mj
Old 11-23-2009, 02:31 PM
Cris@JCG's Avatar
Default Assembled Clamps
Here is a pic of axle clamps assembled with fittings & clips
Old 02-07-2010, 11:37 AM
scherp69's Avatar
scherp69 scherp69 is offline
Chris...any chance these can be built to fit around a 9" with a back brace. I really like them, but don't think they will work for me as I have a Moser M9 with the back brace.
Here's a couple pics of my setup
Or do you think the ones you have would work if I put it between the back brace and the lower shock mount. Here's a pic of where I'm talking about.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 02-07-2010, 02:49 PM
Cris@JCG's Avatar
Mike- I don't think their is a good way to get my clamps to work with the back brace rear-end.. I know we have round tube that we can clamp to but don't think it will give you any good plumbing options.. I got a great idea on how we can machine up some brackets that will mount to the back brace as long it is hollow.. or we have these other tabs that we weld to housing..
Cris Gonzalez
Old 02-07-2010, 02:54 PM
Cris@JCG's Avatar
Looking @ the rear-end closer.. the clamps might work.. you can rotate clamps so that they are positioned on top of the brace so that you can run brake line to the center.. Measure the tube which should be 3.00 OD..
Cris Gonzalez
Old 02-07-2010, 05:56 PM
scherp69's Avatar
Just checked the Moser website...it is 3" O.D. The back brace is hollow. Where on the housing would the clamp fit? with mine, there is a bracket on the top for the short arms and on the bottom (you can see in the first pic) I welded on the bracket for the rear sway bar. I would be interested to see what you have in mind though.
Mike
New Gen Splitters
LS3 and TKO600
Old 02-08-2010, 06:10 PM
Cris@JCG's Avatar
You can mount the clamp on the space between the welded shock mount & the end of the brace.. rotate the clamp so that you can plumb on top of the brace instead of the center of the brace like the pic attached.. or fabricate an L shaped bracket that you can drill to the hollow end of the brace..
I hope this pic helps!
Cris Gonzalez
Old 05-29-2013, 09:36 AM
R4VEN R4VEN is offline
Default Are any of these clamps still availble?
I need a couple of these clamps. Are any left?
Old 05-30-2013, 09:47 AM
Brian - JCG Brian - JCG is offline
Yes, we still stock these. Ironically enough, we just sent our last set out a few days ago. We do have more coming, but will probably be a week or two before they are here..
Brian Short
www.JCGRestorationandCustoms.com
