Old 10-19-2009, 12:13 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default Rear end clamp for brake lines
This fall/winter I plan on running the brake lines on the car. Since I already have the rear end powder coated, I can't weld on any brackets to hold the brake lines onto it. What are you guys using to secure the brake lines to the rear housing??
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 10-19-2009, 12:16 PM
Bow Tie 67's Avatar
Bow Tie 67 Bow Tie 67 is offline
You could fabricate a bracket that bolts up to one of the 9" bearing retainer studs.
Matt
Project: " Chain Reaction "
A.K.A. " BIG " by wife, biatch in garage.
1969 RS Camaro, L92 T56, Chassisworks sub, Quadra-Link, Bear, Ford 9".
Old 10-19-2009, 12:36 PM
I was in the same boat. I used a clamp and drilled a hole in my housing for the bottom link. Do yourself a favor and run a short hose. This will make the rotors and axles servicable later. You'll thank me......
Old 10-19-2009, 02:03 PM
BBC69Camaro's Avatar
I'd grind off the powder coating and weld some brackets on. I did and just touched up with some Por-15 chassis black paint. Not perfect, but heck its under the car. I'd care more about making sure the brake lines are secure.
Stopping >> Perfect undercarriage.
Old 10-21-2009, 08:38 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Run hard lines on the frame, stop above caliper, then run braided line to calipers.
Old 10-21-2009, 11:08 AM
We drill the top of the axle tube, tap it for a 10 - 32 and use a small clamp. I put a dab of permetex in the hole when I put the screw in and have no leak issues as there is not a lot of fluid on the top of the axle tube in the middle of the tube.
Frank Serafine
Old 10-21-2009, 02:46 PM
Fluid Power's Avatar
I was in the same boat. I just ran hard line down the left side of the frame, t'd off with flex line to caliper and hard line across the floor to flex line to caliper on driver side. Nothing on the rear end.
Darren
Old 10-21-2009, 03:46 PM
scherp69's Avatar
Thanks for all the suggestions guys. The funny thing is after I posted this question, I started thinking.....the rear end has a back brace welded on. I could just as easily drill and tap some holes right into the back brace and run it along there. I also like the idea of just running it along the rails and then the floor. I already have the rear together so I don't feel like taking it apart, but I guess if I do decide to run it along the tubes, I will have to take it apart. Thanks again for all the responses.
Mike
New Gen Splitters
LS3 and TKO600
Old 10-21-2009, 10:25 PM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
I have a set of billet clamps I made that clamp on the axle tubes.. I will get you some pics tomorrow..
Old 10-22-2009, 10:03 AM
Cris@JCG's Avatar
Here is a pic of the axle tube clamps.
