Old 02-22-2011, 01:32 PM
Gandalf Gandalf is offline
Planning stages - what's that? You must mean where I was going to spend a weekend getting this driver on the road LOL!
But absolutely. Too many examples of that during this build - my bad and we correct as we go. Almost want to do it over just to see how it CAN be done LOL. But it's all good and we're getting closer.
Can't wait to see your car in person - looks great!
G.
Originally Posted by Rybar View Post
Understood, I meant deciding on a different suspension during the planning stages.
Old 02-22-2011, 02:11 PM
Payton King's Avatar
Default Car looks great with the new wheels and I love the
stance. Most companies running coil overs are using a 5 inch stroke shock. That should give 2.5 compression and droop or 3/2...which is not much. Not sure I would want to go any shorter on the shock just from a bottoming/ride standpoint. Most are running between 250-275 rear spring. If you are going for ride comfort the 200 should be great, but I bet you will have a bottoming problem.
With all that being said....damn you car looks good!
Old 02-22-2011, 03:01 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Originally Posted by pokey64 View Post
Chris, Are you thinking about running shorter springs or modifying brackets and trunk floor? I'm working on a G-link install on my wife's 69 currently. I've only welded points that can be cut easy so far. If you or anyone else has thoughts on this we could start a new thread so we're not hijacking Ryan's.
My choice would be to modify the brackets/trunk floor so that I don't lose shock travel. Not sure yet. I'm working on the engine build for now. I may just see where the car ends up after it's finished and then go from there. It's too early for me to tell because I have no weight in my car. It's still a shell.
Chris
Old 02-22-2011, 03:13 PM
strtlegal's Avatar
strtlegal strtlegal is offline
I know on my Gbar setup there are several holes at the axle to lower the shock mounting. So you dont loose the overal length of 13-14" when lowering it more.
Do you not have this option? Or is it at the lowest setting? I know Im on the middle setting and my quarters sit right at my rims.
70 Nova: LS2/Tko600. Speedtech Stuff
Chuck D
Old 06-08-2011, 12:22 PM
Rybar's Avatar
Rybar Rybar is offline
I know it's been a while, but a local photographer took a nice shot of my car clean this past weekend. I may get him to do a shoot of my car now.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 06-08-2011, 12:23 PM
Awesome! Love the car - love the pic!
G.
Old 06-08-2011, 12:40 PM
What a beautiful shot. The car looks awesome!
Old 06-08-2011, 12:52 PM
Ron in SoCal's Avatar
Top notch Sir!
Ron in SoCal
69 Camaro in progress
Old 06-08-2011, 12:54 PM
Richio1's Avatar
Richio1 Richio1 is offline
Talking
Sweet! Let's see some more...
Jeff
Lateral-g Feature - https://lateral-g.net/forums/showthread.php4?t=44186
Build thread - https://lateral-g.net/forums/show...ght=brownstone
Special thanks to Matt's Classic Bowties along with
Old 06-08-2011, 01:10 PM
skatinjay27's Avatar
nice! fikse's just give the car a high end but simple look!
AJ
