Closed Thread
Old 03-16-2011, 07:43 PM
4SpeedGirl's Avatar
4SpeedGirl 4SpeedGirl is offline
Default Popular Hot Rodding Project Street Fighter Mustang For Sale ('66 Mustang)
Hey guys, it's time for the Mustang to find a new home. For those of you who haven't seen the car in PHR, it's been running in nearly every issue since November 2008. The car is ready to go! I recently had it aligned and corner weighted at Roger Kraus Racing in Castro Valley, CA. It runs and drives though there are a couple really small projects to finish, I may even get to them before it finds a new owner.
$25,000 OBO (preferably plus more than minus )
See all of the stories published so far (still more to come)
http://www.milesspeed.com/fab/mustang.htm
Specs
565 horsepower at 5,600rpm
564 ft-lbs torque at 4,600rpm
Type: 427-ci Windsor
Block: Dart iron, splayed 4-bolt main caps
Oiling: 7-quart Canton oil pan
Rotating assembly: polished and chamfered 4340 forged steel crank, 6.2-inch forged H-beam rods, high silicon forged aluminum pistons
Cylinder heads: Smeding designed AFR aluminum, CNC machined 205cc intake runners, 60cc chambers
Camshaft: hydraulic roller, .544/.573-inch lift, 238/248-degrees duration at .050-inch lift, 110 lobe center
Valvetrain: Scorpion 1.6:1 rockers, 2.08/1.60-inch valves
Induction: Edelblock Victor Jr. intake, 850-cfm Mighty Demon with annular boosters
Ignition: Smedding branded MSD Super Conductor wires and looms, Pertronix ready-to-run distributor
Cooling: Be Cool radiator with dual Spal fans
Fuel system: Rick’s Hot Rods fabricated stainless steel tank, AC Delco electric in-tank pump, Earl’s Pro-Lite hose and Ano-Tuff fittings, Aeromotive fuel pressure regulator
Exhaust: Doug’s mid-length headers, 2.5-inch tubing, Flowmaster Super 44 mufflers
Fasteners: ARP
Drivetrain
Transmission/shifter: Keisler T45RS 5-speed manual, hydraulic throughout bearing, Competition Specialties Stage 4 clutch, Keisler shifter lever
Driveshaft: Steel custom length from Keisler
Rear axle: Chassisworks Fab9 housing with Currie 3rd member, 3.25 gears, Detroit TrueTrac, 31-spline axles
Chassis
Front suspension: Total Control Products tubular upper and lower control arms, VariShock coilovers, power rack, 1 3/4-inch sway bar, big bearing spindles
Rear suspension: Total Control Products G Bar canted 4-bar, VariShock coilovers, ¾-inch sway bar
Brakes: Wilwood 13-inch rotors, 6- and 4-piston calipers, stainless braided lines, Wilwood dual reservoir master cylinder
Interior
Seats: Corbeau Forza seats and belts
Dashboard: JME machined aluminum gauge pod and gauges
Wiring: American Autowire Classic Update kit
Column: Flaming River stainless tilt column, Grant wheel
Body/paint
Body: Fiberglass hood from NPD, body work performed at JCG Restorations, Oxnard, CA
Paint: Summit Racing single stage Bright Orange Metallic and Medium Charcol Gray Metallic with lime green pinstripe
Wheels/tires
Wheels: Vintage Wheel Works V60, 17X8
Tires: BFG R1, 245/40R17
Liz Miles
[email protected]
Email or PM me if you have any questions!
Liz Miles
www.MilesSpeed.com
Old 03-16-2011, 08:16 PM
nice car Liz. We need a price.
Old 03-16-2011, 09:19 PM
chevyhector's Avatar
chevyhector chevyhector is offline
Hola Liz,
Hope you find a seller soon! But just so you know, I've been spreading the word for you. Btw, I didn't know you were a member here, are you on pro-touring.com?
Hector
Love your Family, and LIFE ! God bless
Old 03-16-2011, 09:50 PM
4SpeedGirl's Avatar
DUH how could I forget that!
I've whittled my exceptions down to $25,000
Hector: Thanks for spreading the word for me! I'm at PT also. I'm not as active on either as I would like to be. I really like coming here for readers opinions to put into my stories, I really value you guys!
Liz Miles
www.MilesSpeed.com
Old 03-17-2011, 01:53 PM
MaxHarvard's Avatar
Bump for a fun car!
Old 03-17-2011, 10:36 PM
KSBRKTRACER's Avatar
KSBRKTRACER KSBRKTRACER is offline
Looks like a great price for that car and all the things done to it ....GLWS
Old 03-17-2011, 10:41 PM
BBC69Camaro's Avatar
Seems like a lot of car for the money, good luck with the sale!
Old 03-18-2011, 09:44 AM
Ron in SoCal's Avatar
x2, you definitely could not duplicate that for 25k....
Ron in SoCal
69 Camaro in progress
Old 03-19-2011, 12:08 PM
JNS JNS is offline
wow love the car, just need to sell mine first!
Old 03-22-2011, 10:29 PM
4SpeedGirl's Avatar
looks like I may have a buyer! I'll find out for sure tomorrow
Liz Miles
www.MilesSpeed.com
Closed Thread
