Old 05-31-2011, 12:12 PM
ModernMuseum ModernMuseum is offline
Originally Posted by MarkM66 View Post
The solid aluminum plate Mike is referring to is that plate you're bolting to your engine, that is suppose to put your LS in the right place.
Remove the plates behind the mounts and see if it fits. I agree with Mike, with them being bolted to a flat solid piece, I don't see why they're needed.
Thanks for the replies, gents.
I'll take another look at the mount specifically tonight. I think if you remove the plate though, the rubber doesn't really have any damping qualities.
I spoke to S&P this morning and they are shipping me some "regular" or "original" style mounts. He referred to the ones I currently have (the Energy Suspension mounts shown in the pics) as the "heavy duty" type which may be too thick. When I get them, I'll post up some more pics.
Old 05-31-2011, 02:24 PM
you cannot interchange short and wide with tall and narrow, unless you change the frame mounts also. If these fit over the frame pads snugly (not a 1/4" gap or so) then they are correct. Hopefully the original style mounts solve the issue.
Old 05-31-2011, 04:08 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Those plates that come with the ES mounts are to stop the mount from distorting when bolted directly to an engine block. Since most engine blocks use mounting bossed which extend from the block.
If you bolt them to a adapter plate, these would not be needed.
The "dampening qualities" come from the poly material inside the mount.
Old 05-31-2011, 06:51 PM
Ahh, I gotcha. I'll probably try it with the mounts that I have then without the compression plate before I try the other ones. I think they 'might' fit without the compression plates.
I took some quick dimensions of my pedestals, which are as follows:
Driver's side:
2.5" tall
2-5/8" width
Passenger's side:
2.75" tall
2-5/8" width
The energy suspension mounts I have right now are pretty much 2-5/8" wide as well, so the fit is very snug.
Old 06-01-2011, 12:13 AM
Rybar's Avatar
Rybar Rybar is offline
Todd is correct, I wrecked two sets of the poly mounts before switching to solid. But the mounts felt fine to me, I never noticed any issues until a buddy pointed it out to me, so maybe the preload plates are needed? But I had the same issue as the OP, the motor wouldn't fit with them.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 06-01-2011, 04:56 AM
Hrmm...I'm on the fence now
The only difference I can foresee if I don't go with the pre-load plates is the point of contact. Since the pre-load plates have the ridge in the middle, the only part of the pre-load plate that touches the S&P adapter plate is in the middle. The pre-load plate actually gets warped a little when it is tightened down.
However, without the plate, all of the rubber section in the middle will be touching the S&P adapter plate. It will still be crushed a bit (so I'm guessing it will be pre-loaded), but the engine mount's contact surface will be the full area of the surrounding metal as well as the full rubber area.
With the pre-load plates, the contact surface between the engine mount and adapter plate is the ridge in the middle and the outer perimeter where it bolts down.
Old 06-01-2011, 06:12 AM
AM.MSCL's Avatar
AM.MSCL AM.MSCL is offline
I have been told that the firebirds have a different centerlink then the Camaros and it sits in a slightly different location by about a 1/4" towards the firewall. Due to this fact the Oil pan will sit on it and not allow the engine to fully align with the bolts on the mounts. The Oil pan has to be modified to clear the centerlink.
Hopefully you verified that the oil pan is not hitting something already?!
Old 06-01-2011, 06:30 AM
You are correct. The firebirds and camaros have different center links. The firebird center link is more or less straight and the camaro link has a slight bend in it. I have already taken the center link out and have a camaro center link to put in its place.
I have a champ road racing pan, and I am pretty sure it will clear the bottom cross-member (and hopefully the camaro center-link). I have been told that the 69 sub-frame is the same as a 68 camaro sub-frame.
Old 06-03-2011, 01:25 PM
Ok, I got the "thin" or "regular" mounts in from S&P. There don't appear to be any dimensional differences between them and the Energy Suspension mounts. The "regular" type just have the back plate molded into the rubber as a single piece, but after several measurements, they appear to be the same dimensionally.
I guess my only option is to use the Energy Suspension mounts and leave the back compression plate off. Hopefully this will mate up and not shorten the life of the mount. I don't really see how it would shorten the life since it's mated to the adapter plate though. I just foresee a slightly different loading on the rubber part of the mount, since the rubber will be flush with the adapter plate instead of the wedged back plate being present.
Old 06-03-2011, 02:47 PM
Rybar's Avatar
Or just run solid mounts
1969 CAMARO RS
