Old 03-20-2012, 08:42 PM
Ron in SoCal's Avatar
Default Budget suspension project
Fun stuff....
I've got a buddy w a 69 Camaro - all stock - and he's looking to upgrade his suspesnion. Budget is 4k including shocks, brakes and rear leafs (parts only if all bolt ons). Intended use is spirited street driving maybe an AutoX or two but mostly street (99.99%).
Constraints are build around ATS/Speedtech tall AFX spindles. Use Kore3 c5 brakes.
What would you do? I have a plan, but want to hear all opinions...
Ron in SoCal
69 Camaro in progress
Old 03-20-2012, 09:18 PM
Track Junky's Avatar
Are the spindles included in the 4K? Has he bought wheels yet. Reason I ask is he will have to pay attention to backspace with ATS spindle if he's shooting for bigger than a 245 up front..
Personally, I wouldnt spend over 25% of the budget on spindles. Use the stock spindle and check to see if he has the short steering arm. You say he's using Kore 3 brakes. Whats left in the budget?
Gaetano Cosentino
Old 03-20-2012, 10:24 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
My 67 had an Quick Steer steering box from AGR and I really liked it. Just a suggestion.
Curtis
Old 03-20-2012, 11:02 PM
Sieg's Avatar
Sieg Sieg is offline
$4K........does he plan on cheating a little?
I'm in the middle of installing Kore3 C5 fronts with a Wilwood 7/8 master, prop/distribution valve, new copper/nickle tubing, Hawk HP Plus pads, DBA slotted rotors on stock spindles. Lee just received my steering box today to rebuild with 12.7:1 ratio with 32 lb firm valving........approx. $2200 not including the inevitable incidentals.
Rear discs with parking brake are approx. $1450 and I'm under the assumption they are likely subject to knock back issues with the stock 12 bolt set up?
F&R Springs, Koni shocks, Hellwig swaybar, DSE shock plates, Guldstrand mod, new control arm bushings, ball joints, tie-rod ends, alignment?
Very interested to hear what you have in mind.
Old 03-20-2012, 11:14 PM
If your looking for an inexpensive way to make your car handle decently pick up CPP UCA's for $400 and keep the stock lowers. Use the QA-1 single adjustables with 550 lb springs. That will get you by just fine for street and auto-x. I've used the DSE and Global West sway bars and they are both similar and work well.
Gaetano Cosentino
Old 03-21-2012, 07:51 AM
Thx for the responses guys. The guy already bought the spindle before he asked for help. You guys are pretty much on it. My idea - GW uppers, del-alum throughout, GW front swaybar, QA1 singles front and rear, GW L-2 cats. AGR box and hopefully a couple bucks left over.
Mike also had a good idea - sell the spindles and go DSE Speed I front and and rear. Makes sense as there's no mix/match and no reinventing the wheel.
Ron in SoCal
Old 03-21-2012, 08:01 AM
Roberts68 Roberts68 is offline
Default subscribed
Spill it Ron,
I am interested in the whole schpeil especially since I am looking at my $4k in combined refunds.
I already have a laundry list of parts squirreled away, and have flopped back and forth on various notions like a fish out of water for some time.
I would very much like to hear if the ATS are coming out of the $4k as others inquired. Wouldn't tall ball joints be a much lighter hit on the budget?
Old 03-21-2012, 08:05 AM
Blake Foster's Avatar
there is this other company that has a bunch of stuff that you might consider????
Blake Foster
www.speedtechperformance.com
Old 03-21-2012, 08:08 AM
Does the "other" company you speak of offer Purple Kool-Aide?
Old 03-21-2012, 08:12 AM
bret's Avatar
bret bret is offline
Supporting Vendor
Well, I may as well put my hat in the ring as well
http://www.ridetech.com/store/1967-1...er-system.html
If you are truly going to chase some track day or autocross stuff you might want to upgrade to the SA Series coilovers that are rebound adjustable for an extra $300.
Bret Voelkel
President
RideTech
Air Ride Technologies, Inc.
