Old 04-02-2012, 06:12 PM
mexMan's Avatar
mexMan mexMan is offline
have you tought about enclosing the stacks into the hood like the crossram '69 Camaro you're modding? Though that would require pumping some holes into the hood and I don't know if you (or the owner) would want that...
''Every car has a great quality, is not the hands that build it, is the dedication behind it.''
Old 04-02-2012, 08:11 PM
FETorino's Avatar
FETorino FETorino is offline
Now if you could just talk the owner into putting some tires under it.
Rob in SoCal
Old 04-03-2012, 06:09 AM
RS-Chris's Avatar
RS-Chris RS-Chris is offline
Supporting Vendor
Would be cool but might be a little to custom looking. Owner is dead set on it looking pretty factory appearing - at least at first glance...
[B][FONT="Arial"]WWW.ROADSTERSHOP.COM
Old 05-23-2012, 02:25 PM
FETorino's Avatar
So what's the latest on the grocery getter?
Rob in SoCal
Old 06-11-2012, 02:35 PM
Roadster Shop's Avatar
Supporting Vendor
RoadsterShop.com
Here are a few updates on the Fairlane. The car is also currently about to begin the body work phase so these are some catch up shots from the last month or so.
Filled all of the factory seams on the car. here is a good before and after on the driver's sail panel.
Fabbed up an aluminum center console. A machined plate will be made to match the ribbed/finned look of the original Galaxie consoles of the day. (The stock holes for heat and stereo are still to be filled in the dash. A ribbed insert will be machined to house a center A/C vent and A/C controls.)
There was a lot of unique work done under the hood. I was out of the shop unfortunately and did not get a lot of good completed pictures before it was torn down.
Upper radiator close out panel fabbed to enclose the custom radiator and BMW latches.
The inner fenders were designed to have some what of a stock feel with the thick beads.
We then went back and fabbed aluminum tanks into the fenders for the coolant overflow and power steering reservoir.
www.roadstershop.com
Old 06-11-2012, 02:39 PM
67greengt 67greengt is offline
Amazing work Phil!
Old 06-11-2012, 02:48 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
I Love it!!
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 06-11-2012, 03:16 PM
sokoloka sokoloka is offline
Any chance you guys offer unpaid internships? I'd love to hang around for a week just to learn some metal fabbing skills.
Everything you do is FANTASTIC. I'm originally from Naperville so lodging wouldn't be too far away
Eric.
1972 Corvette Coupe - https://lateral-g.net/forums/showthread.php4?t=36573
Old 06-11-2012, 03:32 PM
wiedemab's Avatar
wiedemab wiedemab is offline
Sorry if I missed it, but what are you using to fill the seams? no-lead body solder?
Fantastic fab work as usual. This car is freakin' killer!
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 06-11-2012, 08:25 PM
I love the fab work, and thats a slick idea for the tanks .
wiedemab beat me to it but I'd like to know what you use for the seams too.
Thanks.
