Old 06-27-2012, 05:53 PM
Motime's Avatar
Motime Motime is offline
Default Tank Venting
What's the simplest way to vent a DSE (Rock Valley) EFI tank?
Old 09-11-2012, 05:55 PM
parsonsj parsonsj is offline
Our solution is simple and effective. Install it in the trunk floor under the package tray and connect it to the vent port of the tank. There's no plumbing in the trunk, and no gas smell in your garage.
http://www.iimuchfabrication.com/fuelvent2.html
John Parsons
Old 09-12-2012, 10:40 AM
Rybar's Avatar
Rybar Rybar is offline
John can you explain how that device works or installs? Does this also keep the vent line from spilling out fuel on a full tank? You have my interest.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 09-12-2012, 12:07 PM
The vent is installed in the truck floor underneath the package tray with all plumbing interfaces on the outside (underneath) of the car. The tank vent port connects to the vent input port.
Installing our Vent along with an unvented fuel cap will virtually eliminate fuel smell from the vent port, and will cure fuel slosh problems that often happen with a full or nearly full tank. It will aid in burp-free fill-ups, and also provides filtered air to the tank as fuel is burned by the engine, easing the work of the fuel filter.
John Parsons
Old 09-13-2012, 04:19 PM
coolwelder62's Avatar
I got my II much vent today.Wow!!! this thing is an awesome pc.Well worth the money.And this from a guy who build's 90% of his own part's.
Old 09-13-2012, 06:20 PM
Thanks Scott! Your voicemail made my day! Now lets see some installation pics.
John Parsons
Old 09-13-2012, 09:36 PM
kochevy67's Avatar
kochevy67 kochevy67 is offline
How much are they?
Old 09-13-2012, 10:02 PM
camcojb camcojb is online now
Originally Posted by kochevy67 View Post
How much are they?
Old 09-13-2012, 11:45 PM
4mm 4mm is offline
Kool product, I will be ordering two next week!
Old 09-14-2012, 05:29 AM
John,It is so refreshing to get part's that are way cooler than you expected.
