Old 01-23-2013, 08:39 AM
glr0212 glr0212 is offline
Default 69 Camaro - The Hard Way
Thanks for checking out the thread. I wanted a place to put all of my pictures and document the build. I also wanted a place to ask questions and gain some motivation from other car freaks.
So quick back story... This is my first car. Bought it in 95 for $3800. Those were the days right? Complete running car, everything worked 12 bolt rearend.
Come to find out the car was somewhat of a basket case but I learned a lot working on it. Stripped the thing down in 99 to paint it and discovered some nasty quarter panel repair work. Ended up slapping bondo on it because I didn't have the money to change the panels back then.
After paint in 99 -
In 2003 I took the car apart because the bondo on the quarter panels was cracking, the valve stem seals were leaking, and I thought it would be cool to put a Global west coil over front suspension in the car.
Of course I took the car apart and lost most of the pieces and here I am 10 years later trying to put it all back together again. [s]I’m not made of money nor do I own a shop so this is just a guy building a car the best he can in his garage.[/s] [EDIT]<--- I gave up building the car and let Roy finish it. You probably aren’t going to see anything earth shattering on this car but a lot of threads like this one have helped me out so hopefully this one will do the same for someone else.
Anyway, on to the good stuff (pics)…
Back from the black hole of one shop (7years) into the black hole of another (2 years)
Home finally after nearly a 10 year journey - 10 years to get the quarter panels changed and the Chris Alston Chassisworks rear suspension installed
Last edited by glr0212; 09-21-2017 at 02:23 PM. Reason: Pictures deleted F*CK photobucket and dropbox
Old 01-23-2013, 08:49 AM
General direction of the car thus far-
Minitubbed 18x12 & 18x9.5 wheels - 335 and 265 tires
14" C6 front brakes - LS1 rear brakes (for the time being)
G Link rear suspension
RideTech’s true turn
355 roller motor, carbed, dart heads, made 490 on the dyno with full accessories. Dynatech headers
Magnum T56 trans. 3.90 rear end
Ricks stainless gas tank
No decision on the radiator
AAW wiring harness. Mad electrical components - rear mounted battery.
Recaro seats out of a an Is 3 series BMW
Old 01-23-2013, 09:10 AM
will69camaro will69camaro is online now
Excellent start man. I can relate to the long build process. Hoping to gain speed soon.
Where are you located? Camaro Concepts has helped me out quite a bit as well and did all the metal work on mine. Cant wait to see the progress on the car. Idea on what final color will be?
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 01-23-2013, 10:20 AM
Rybar's Avatar
Rybar Rybar is offline
Yup I can relate alot as well, good luck man you came to the right site.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 01-23-2013, 10:38 AM
Thanks guys.
I guess I should say that I've gotten most of the above stuff done and will be posting pics of things as I have time.
as far as color I bounce back and forth between
1. all black
2. Dark gray
3. Fathom Green
no stripes
Currently she sits about like this
Old 01-23-2013, 11:39 AM
Nice project
Old 01-23-2013, 11:51 AM
Where are you located? Wheels look good! Dark metallic gray would be very cool (Like GM Cyber Gray).
William
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 01-23-2013, 11:55 AM
I'm inside the loop near downtown
Old 01-23-2013, 12:20 PM
I guess I will start with the front suspension
I have the ridetech setup, full uppers, lowers, springs, shocks, swaybar, and tru-turn.
I bought all that and the 600 box through Frank at prodigy about a year and a half ago. I think he forgot about the order for a month or two but I started pestering him and it finally shipped out and I got it. I wasn’t in a hurry so it worked out ok. Interesting how that guy went from pro-touring hero to heel in about a year.
On the fit/finish/install of the ridetech stuff I’d probably give it a B. I had to hack away the bump stops on the frame to get the sway bar to work.
I also feel like the threaded end of the rod links provided in the drag link kit were too long. I don’t know, maybe I’m missing something. One of the bolts provided that attach the drag link to the adaptor did not have a hole for a cotter pin.
The dynatech muscle max headers cleared the tru-turn and fit really well except where the #7 tube hits the gear box. I’m currently working on that with a grinder, a torch and a hammer.
No Picture of that right now
Honestly if I could go back I would probably order a TCI subframe. For a little more than what I have in the current setup I could have gotten a complete subframe. Something to think about.
Old 01-23-2013, 12:21 PM
Roberts68 Roberts68 is offline
Looks like a great project, and you appear to have the worst behind you.
Keep the pics coming
