Old 02-21-2005, 08:06 PM
Jerebus67 Jerebus67 is offline
Default Suggestions on Rims
I have a 67 Convertible and put the Detroit Speed front and rear suspension kits on my car. We installed the minitub kit as well. I really like the Centerline Lazer Rims but the widest they come in is 10. I believe with the minitub kit 12.5-13 will fit and I might as well put as much meat as I can.
Any suggestions on something that looks similar? Cant wait for the spring!!
Old 02-21-2005, 08:21 PM
XcYZ's Avatar
XcYZ XcYZ is offline
If you're still running leafs, the widest you can go is 12", maybe 12.5" without the tires rubbing on the leafs. Personally, I think a 335 fits a 12" wheel perfect.
Now, as far a choosing a wheel, that's about as hard of a decision as you're going to face with your project. Just ask those around here that have struggled with that!
My LS7 69 Camaro
Old 02-21-2005, 08:26 PM
I really like the rims on Jeff Thrush's camaro have you guys found anything similar? Any websites I should check out??
Thanks for the help!
Old 02-21-2005, 10:29 PM
BC69's Avatar
BC69 BC69 is offline
I think, and I hope I am not wrong, but Jeffs are Centerlines...someone correct me if I am wrong. You can check out some of the popular rim sites.
www.Budnik.com www. Bonspeed.com some of the higher prices rims are Fikse (www.fikse.com??). I was buzzing through Budniks wheels today, I think you can find a variety of wheels close to Thrush's style. I am bonspeed fan myself. Look through the projects and feature cars to see a some styles in place on Camaros too.
Hope this helps.
Tim
In memory of those gone before us
In gratitude for those who care.
Old 02-21-2005, 11:12 PM
trapin's Avatar
trapin trapin is offline
Jerebus67...whenever you decide on a rim and tire combo, I would suggest purchasing them through Discount Tire (if you have one near you). I went through them with my Billet Specialties and Nitto set-up and they were $400 cheaper than the nearest competitor, I couldn't believe it. They can get anything too. Be sure to check with them on price before you make your purchase.
Tony Rapin
The Pigeon Forge Project
A 1968 Pro-Touring LS1 Camaro.........and why not?
Old 02-22-2005, 08:05 AM
Payton King's Avatar
Default wheels
I really like the BC09 wheel. www.bcforged.com
They are about $400 a wheel with any offset you like in a 17 and about $450 in an 18.
Old 02-22-2005, 08:33 AM
61Bubbletop's Avatar
61Bubbletop 61Bubbletop is offline
Lateral-g Moderator
Default Centerline
Yes, The wheels on my car are Centerline Lazers. They are every similar to a Z06 wheel, Soft Lip, inside mounted valve stem, very nice build quality. Centerline may build you a set wider if you requested it.
Oh, and its Trush, Thrush is a Muffler!
Pics if you haven't seen these wheels before....
Old 02-22-2005, 10:45 AM
Another question.
I just got off the phone with DSE and they gave me these specs.
Rear - 315 tire on an 11 rim
backspacing of 5 - 5.25
They suggest narrowing the axle. Do you need to narrow the axle?
front - 8 inch with 4 7/8 spacing
Anyone have any input on the axle question? Thanks for your help!
Old 02-22-2005, 12:12 PM
907rs's Avatar
907rs 907rs is offline
Jerebus, you don't need to narrow the axle, but Imo if you're running a 315 or 335 tire on an eleven or twelve inch rim the offset required to do so just doesn't look right.
But, it is your car so the desicion is ultimately your own.
I went with the 335/30/18 on an 18x12 Budnik Fontana with 6" of backspace.
You can also go to the Lateral-G homepage to see wheels in similar sizes and backspace installed on cars.
Bill
Old 02-22-2005, 02:22 PM
trapin's Avatar
Payton King....
Those BC Forged Wheels....can you get them in a 11" wheel? I only see 10's as high as they go.
Tony Rapin
