Old 02-27-2014, 06:16 PM
jlwdvm jlwdvm is offline
.....I'm not sure Vintage Air makes a kit for a non-AC application.
Old 02-27-2014, 06:33 PM
67machrod 67machrod is offline
Check out drivejunky.com. I just ordered a kit today from them.
Old 02-28-2014, 02:57 AM
65_LS1_T56's Avatar
65_LS1_T56 65_LS1_T56 is offline
Originally Posted by jlwdvm View Post
Interesting.....how did you get this done? Looks great! Thanks for all the help.
I started with a F-body setup. The low mount alternator was occupying the same space as the steering box so it had to move. I didn't want air on it and I never cared for the look of the the ps pump and alternator hanging off the drivers side and nothing but an idler on the passenger side.
So I found and alternator with side lugs and started with it infront of the ps cylinder head and worked it out from there. It basically is 10mm (.394") further forward than the F-body accessories are stock. I moved the tensioner to the old alternator position and made a bracket for that and the power steering pump too.
The balancer is SB Chevy for a bolt on pulley from ATI with a short March pulley with a spacer to position the drive belt inline.
It was a lot of work to design and machine all the brackets but it does work well and is pretty compact too. As you can see, there is good belt wrap on everything, something I was planning for as I was figuring it out.
Hope that helps,
Aaron
65 Chevelle
Project G-Velle
66 Corvette, Spirit of '66
Project G-Vette
Old 02-28-2014, 07:21 AM
My Texas Speed motor comes with a C6 non-AC system. I've looked at the DriveJunky systems already and they look very similar to the C6. I need a non-AC system. Texas Speed will change out the c6 system if I find a different one that I like. They will also change out the GM Hot Rod oil pan that comes with the motor. Looking at a Holley 302-s, put am open to suggestions for a road course compatible pan.
Old 03-01-2014, 08:09 AM
forcepower forcepower is offline
I'm running the stock corvette set-up as it is the most compact from the factory. It also was a complete pull out
Old 03-01-2014, 10:48 AM
C6? Is the alternator high on the drivers side?
Old 03-01-2014, 07:36 PM
Just think why pay 2000+ bucks for billet drives when you can gm engineered systems way cheaper. All gm kits can be bought without ac. And brackets can be easily sanded and painted if want custom look.
Google C6 drive and you can see how it fits. I have one in my camaro and it fits perfect.
63 Z06
Old 03-05-2014, 08:53 AM
yes from a c6. here is a pic:
[IMG][/IMG]
[IMG][/IMG]
Old 03-06-2014, 09:48 AM
Check out post 14 and 18....what set up is this and will it work on an LS3? I think they are F-body drives?
https://lateral-g.net/forums/show...t=19486&page=2
Old 03-06-2014, 11:49 AM
yes,those pics look like the f-body set-up
