Old 07-28-2016, 09:57 AM
Better get busy Michael -- you only have a few days before Sonoma! LOL
Looks good buddy!
Old 07-28-2016, 12:50 PM
Sonar Chief's Avatar
Smile
Originally Posted by grendel View Post
New fan mounts? Mine are just black plastic... off to call Tony.
JJ ... sorry for the spoiler picture. Question, did you purchase the fan controller also? If so, do you have a starting point for setting the temp dip switches? The wiring is not all that hard to figure out, may have to increase the length of the battery positive thou!
Nice progress as for the exhaust any chance you can remove some of the trunk floor and go into the trunk around the tank and come back down.
Not sure what tank your using but you can also consider using a mustang style tank that drops in from the top and give you plenty of extra space for exhaust.
You can see that the well in the trunk has been removed and the tank has been elevated up to make the trunk floor flat. Which also hides the tank and allows you
to place a crash bar across the rear frame rails to protect the tank at the back of the car.
I have thought about all that, went through pics of Mayhem with a microscope, he raised the trunk floor level with the side kickouts and welded on new gas tank/ floor braces/ brackets ... that worked with his Quadralink.
Different with the RT 4 bar though, I would have to support/brace Ride Tech's sway bar that bolts to the trunk floor with a brace from the roll cage ... not sure how much clearance that would gain! Still trying to engineer it out like Mark would do, even thou I'm not an engineer ... might have think outside the box
Looks good buddy!
Hey thanks Greg, I will be there Saturday morning driving up without the car though ... soon she'll be road ready!
Michael
Old 07-28-2016, 12:55 PM
grendel grendel is offline
Yep. I did the fan controller. Not sure I need it, since the FAST or Dakota Digital system will run it for me, with the AC.
Interestingly enough, I haven't installed anything yet. Getting there shortly, but the radiator doesn't seem to fit the support I have.
68 GMC C1500
Haulin more than the mail
73 Camaro
Better grow a mullet
70 K5 - 4wd turned 2wd
Project might as well...
Known as John or "JJ"
Old 07-28-2016, 01:48 PM
Cool
Yeah, the GM will run it also, just liked the idea of series/parallel dual fan controls without the hit of dual fan start up, that's a lot of amps!
Hmmmm ... I have the OEM radiator support and an AMD sitting in the bedroom, guess I'll have to check fitment tonight!
Old 07-28-2016, 10:20 PM
Sorry, it was the aftermarket sub frame. I cut it to fit the radiator. I would have had to cut it for any radiator.
Yeah, I plan to use their fan controller, too. I am calling Tony tomorrow to figure switches.
I do want the aluminum fan covers now. They look pimp.
68 GMC C1500
73 Camaro
Old 07-29-2016, 12:44 PM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
Originally Posted by Sonar Chief View Post
Thanks, me too!
Working in the garage when it's not so dang hot got most of the micro-tub welded in the last few days, need to final fit and get the vertical close-out cut and welded in .... phew that'll off the list!!!
Then the brown truck showed up today with my radiator .... nice unit fer sure, but there is a lot of wiring in that box, guess I'll have to do some reading soon.
More tomorrow, thanks for looking ...
Looking really good!!
Old 07-30-2016, 01:02 PM
Cool
Ok, cool post up a starting point will ya?
This is the cat's pajamas! Figured I'd try some of this Evapo-rust on my foot pedal bracket ... wow! I should have ordered more than a gallon cuz I couldn't submerge the part completely and had to keep shifting the part. Need a touch up but it's ready for some primer. My ER brake bracket is soaking now!
Though I'd share a product that actually works ....
Old 07-30-2016, 06:20 PM
I'll get some info this week.
Thing is, mine will be run by the FAST EFI controller.
68 GMC C1500
73 Camaro
Old 07-30-2016, 06:24 PM
Smile
Twins ... well, I can check that off the list!
Still need to dress her up a little, but that's another day!
Thanks for looking ...
Old 07-31-2016, 09:18 PM
califconstruct's Avatar
califconstruct califconstruct is offline
Looking good there!.. nice radiator!.
Your definitely coming along.
I'll have to get over there and check this thing out personally!.
