Old 07-28-2016, 06:46 AM
syborg tt's Avatar
Nice progress as for the exhaust any chance you can remove some of the trunk floor and go into the trunk around the tank and come back down.
Not sure what tank your using but you can also consider using a mustang style tank that drops in from the top and give you plenty of extra space for exhaust.
You can see that the well in the trunk has been removed and the tank has been elevated up to make the trunk floor flat. Which also hides the tank and allows you
to place a crash bar across the rear frame rails to protect the tank at the back of the car.
marty-mj
Old 07-28-2016, 07:57 AM
Better get busy Michael -- you only have a few days before Sonoma! LOL
Looks good buddy!
Old 07-28-2016, 10:50 AM
Sonar Chief's Avatar
Smile
Originally Posted by grendel View Post
New fan mounts? Mine are just black plastic... off to call Tony.
JJ ... sorry for the spoiler picture. Question, did you purchase the fan controller also? If so, do you have a starting point for setting the temp dip switches? The wiring is not all that hard to figure out, may have to increase the length of the battery positive thou!
I have thought about all that, went through pics of Mayhem with a microscope, he raised the trunk floor level with the side kickouts and welded on new gas tank/ floor braces/ brackets ... that worked with his Quadralink.
Different with the RT 4 bar though, I would have to support/brace Ride Tech's sway bar that bolts to the trunk floor with a brace from the roll cage ... not sure how much clearance that would gain! Still trying to engineer it out like Mark would do, even thou I'm not an engineer ... might have think outside the box
Looks good buddy!
Hey thanks Greg, I will be there Saturday morning driving up without the car though ... soon she'll be road ready!
Michael
Old 07-28-2016, 10:55 AM
grendel grendel is offline
Yep. I did the fan controller. Not sure I need it, since the FAST or Dakota Digital system will run it for me, with the AC.
Interestingly enough, I haven't installed anything yet. Getting there shortly, but the radiator doesn't seem to fit the support I have.
68 GMC C1500
Haulin more than the mail
73 Camaro
Better grow a mullet
70 K5 - 4wd turned 2wd
Project might as well...
Known as John or "JJ"
Old 07-28-2016, 11:48 AM
Cool
Yeah, the GM will run it also, just liked the idea of series/parallel dual fan controls without the hit of dual fan start up, that's a lot of amps!
Hmmmm ... I have the OEM radiator support and an AMD sitting in the bedroom, guess I'll have to check fitment tonight!
Old 07-28-2016, 08:20 PM
Sorry, it was the aftermarket sub frame. I cut it to fit the radiator. I would have had to cut it for any radiator.
Yeah, I plan to use their fan controller, too. I am calling Tony tomorrow to figure switches.
I do want the aluminum fan covers now. They look pimp.
68 GMC C1500
73 Camaro
Old 08-10-2016, 11:45 AM
How we set the controller.
68 GMC C1500
73 Camaro
The Following User Says Thank You to grendel For This Useful Post:
LSX69 (11-06-2020)
Old 08-10-2016, 01:49 PM
Nice job on the tubs! Sweet looking radiator too.
Old 08-10-2016, 02:56 PM
Cool
JJ ... sent you a PM
Thanks Wayne, they came out nice, wait til you see what I've been doing or should I say re-doing....... pics later.
Old 08-10-2016, 05:27 PM
I'll be watching!!
