Old 12-09-2016, 08:46 AM
qtrracer's Avatar
qtrracer qtrracer is offline
On my strut car with an iron block and heads, a 300# C/O has a wheel rate of 270#. This wheel rate more than exceeds the wheel rate of conventional springs in the 1000# range. I think a wheel rate calculation is more relevant than static spring rate.
So what are the wheel rates we are discussing?
Old 12-10-2016, 03:22 PM
aany001's Avatar
aany001 aany001 is offline
I am gonna swap out my coil overs for a set of ride tech to match my 4 Link. I was taking some measurements that Ryan asked for at ride height and was wondering if my lower control angle is ok? The bottom of the control arm is not level to the ground.
Old 12-14-2016, 02:42 PM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
Originally Posted by aany001 View Post
Josh I'm in the middle of installing your 4 link in the rear and so far I'm extremely impressed with your product and customer service. I would love to match my front to my rear suspension but with our dollar its just not in the cards this year.
Thanks for the good words, they're greatly appreciated!
I definitely understand, the exchange rate definitely doesn't help. Just let me know if I can help you in the future with anything.
*edit, I just now saw your post saying that you were measuring up for our coilovers. Did you get everything figured out on that? My direct line is 812-481-4734 if you need help.
Old 12-15-2016, 09:18 AM
Rod P's Avatar
Rod P Rod P is offline
Originally Posted by Josh@Ridetech View Post
What he said.
Depending on the motion ratio, it really varies but 350lb sounds very light on a coilover. For example, with our control arms and their motion ratio, we run a 650lb for a street/daily driver feel.
The firmness that you're experiencing could be cause by coil bind, shock bottoming out, etc.
Originally Posted by TheJDMan View Post
I tend to agree with Rod, I would expect to be running a much heavier spring say in the 500 to 600 range. That said, you should be able to adjust the ride quality with the shock adjustment.
Originally Posted by Blake Foster View Post
i would have sold you 550 lb springs for that combo.
just to ad gas to the fire. i think 350 is too light and agree with Rod that you then need to adjust the compression way up to have the car not bottom out.
ok so were all in agreement! how does this help you? give me a call when your ready and I will help you on pricing also, with honest, along with no bull**** just real advice
what springs are you running on the rear? lets get you with the right rear spring before you install what you have...you can exchange them before installation!
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 12-16-2016, 08:28 AM
^ and I guess that Rodney is a knowledgeable guy as well...
Old 12-16-2016, 09:16 AM
Rod P's Avatar
thanks Joshy! congrats on the marriage, were was my invite
Rod Prouty
Bangshift Stories
Old 12-16-2016, 11:48 AM
Anytime Rod! and thanks! Haha, it wasn't a real big shindig, just close family
Old 12-16-2016, 03:41 PM
David Pozzi's Avatar
Originally Posted by ADY View Post
I have Art Morrison subframe and C6 control arms with T56 and SBC and I have QA1 12" rated at 500lbs and Strange adj. shocks. Definitely not a smooth ride on city streets, but about what I expect considering the ride height.
A 500 lb coil on a Morrison sub has the same wheel rate as a 950 coil on a stock sub.
http://www.PozziRacing.com
Old 01-28-2017, 08:26 PM
aany001's Avatar
I picked up a set of 550lbs 10" long coils from QA1. Installing them in the next few weeks. Keep you posted on how it works out. Thanks to everyone for their help.
Steve
