Old 10-26-2018, 11:08 AM
Brianstanford Brianstanford is offline
I used self etching primer on mine. Then rattle canned it matte black. Both sourced from a body shop paint supplier.
https://lateral-g.net/forums/showthr...assman&page=48
post#472
That's what I'm planning on doing. Think it looks good that way
Instagram @brianstanford
Originally Posted by rickpaw View Post
You're making great progress. Looking forward to seeing it in person.
Thanks man. Looking forward to seeing yours too!
Old 11-05-2018, 06:04 PM
trying to figure out the wiring for a neutral safety switch on the clutch pedal.
i think this is the correct way to wire it.
-"start" position on ignition switch sends power to purple starter wire and pin 85
-once clutch pedal is depressed, closing switch to ground. energizing coil in relay
Old 11-05-2018, 07:57 PM
Just read from #1 post to the end —— and all I can say is WOW! And I don’t mean wow about the car..... but to see what you’ve done and had to endure - rotting old pile of car (all of em are like that by the way) - Baby boy! (Need updated pics!!) and a Flood.... and your car still keep progressing. I’m seriously impressed young man (at 65 I can say that).
I’d try to help with the safety switch but my cancer med has kicked in - so brains don’t work very well after that.....
I have some things to say about the rear end centering - but will hold this thought until I can really write what I want to tell you. It’s not bad — I don’t post bad — I want to help and try to help save you some headache at the same time - but that is going to need my full attention.
Just wow — still shaking my head at you! What perseverance you have!
The Following User Says Thank You to GregWeld For This Useful Post:
Brianstanford (11-05-2018)
  #105
Old 11-05-2018, 08:27 PM
Thank you sir! yes, it's been a wild ride haha. It hasn't been easy but i have learned a lot from it!
As far as the rear end centering- I've been in contact with ridetech and Josh has gotten me lined out with it. I installed the tabs with the pinion at a -3 angle and it needed to be a +3 angle(my fault for not reading the instructions). I haven't fully welded the tabs on yet, just a strong tac weld. It's looking much better
Old 11-06-2018, 12:45 AM
Beechy's Avatar
Beechy Beechy is offline
YES.....assuming the "clutch switch" closes the circuit when the pedal is on the floor.....
Jim Grant
Melbourne, Australia
(Dual citizen)
The Following User Says Thank You to Beechy For This Useful Post:
Brianstanford (11-06-2018)
  #107
Old 01-15-2019, 10:40 AM
Questions about fluids--- Brands & weights welcome!
What oil to use? 70k mile LS2 unknown history of what oil has been used
What coolant to use? All aluminum motor, griffin rad. with overflow tank
T56 is dexron 3?
Power steering?
Old 01-16-2019, 08:54 AM
rickpaw rickpaw is offline
T56 is dexron 3?
Power steering?
I have similar drivetrain set up as yours, but my LS2 is a rebuilt, and I used the following:
-Engine oil: Penzoil 5-30W (non synthetic). Used Walmart cheap oil in the first 50 miles.
-Coolant: Prestone green premix
-TR6060 - Walmart cheap dexron 3 first, as the trans is used. Then changed out to Redline D4 after 200 miles.
Tu Ho
The Following User Says Thank You to rickpaw For This Useful Post:
Brianstanford (01-19-2019)
  #109
Old 01-19-2019, 08:12 AM
Got the battery hooked up and function tested my wiring. All seems good so far. Fluids and gas this weekend/week for the first fire up
Clutch pedal neutral safety switch worked perfectly
Old 01-19-2019, 08:14 AM
Thanks! Why green instead of dexcool?
