Old 05-22-2020, 05:38 AM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by DKz Garage View Post
Mark...... I wonder if you would have some input on brake line size. I know a lot of your recent builds have ABS. What size brake line do you use? I'm using the DSE master (GM part) and booster on my 69 ...I will be making all my own brake lines and was looking to use 3/16" for the entire car. I know GM used 3/16 in the front (disc brakes) but ran 1/4" to the rear? Could you shed some light on what you normally do with your cars?? Thanks in advance.
On my builds I do 1/4 lines to the ABS module and 3/16 to the corners. In general if you copy what GM does it will work. GM and most OEMs are either cheap, worried about safety or durability. For ABS the bigger line is need to supply the volume of fluid needed for the ABS module. For a passive system that you are not gong to track 3/16 for everything should be good. If I was going to track the car with big brakes I would do 1/4 to the tee for the front and rear systems, Then 3/16 to the corners.
Mark
Stielow Engineering
The Following 8 Users Say Thank You to Stielow For This Useful Post:
69hugger (05-23-2020), camcojb (05-22-2020), colorado80439 (05-22-2020), DKz Garage (05-22-2020), Goosesdad (05-22-2020), kwhizz (05-22-2020), syborg tt (05-29-2020), WILWAXU (05-23-2020)
  #382
Old 05-22-2020, 08:01 AM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
Mark
Thank you for your input!!
Old 05-22-2020, 09:57 AM
Stielow's Avatar
Stielow Engineering
The Following 5 Users Say Thank You to Stielow For This Useful Post:
Goosesdad (05-24-2020), kwhizz (05-22-2020), Sonar Chief (05-22-2020), syborg tt (05-29-2020), WILWAXU (05-23-2020)
  #384
Old 05-22-2020, 11:20 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Nice, as usual Mark...
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 05-24-2020, 01:13 PM
DKz Garage's Avatar
Mark, What has been your experience with the Hooker Black Heart exhaust system designed by Holley for the 69 Camaro with DSE sub and Quadralink? Does it fit in nice, any mods needed to make it work? I'm running and LT4 with all Holley mounts/crossmember. Did you use the Hooker system on your last build (LT4) ??
Old 05-24-2020, 03:10 PM
Stielow's Avatar
Yes it works great!
Stielow Engineering
Old 05-24-2020, 09:18 PM
cjfirstgen's Avatar
cjfirstgen cjfirstgen is offline
Mark
Would you do the same size lines 1/4 to the tee front and rear with manual big brakes for the track? Note: 7/8" bore size master cylinder and caliper piston area spec'd for a manual big brake setup
Project "Mercury Rising" '69 Camaro : https://lateral-g.net/forums/showthread.php4?t=41460
Old 05-25-2020, 06:18 AM
Stielow's Avatar
If I was building it I would use 1/4. I think 3/16 would be fine.
I don’t have any good data on passive brakes. I have not used them for 12 years.
On my older builds I did 3/16 to the front tee.
It worked.
Mark
Stielow Engineering
Old 05-25-2020, 08:33 AM
Musclerodz's Avatar
Mark
The reality of just how far ahead of the curve Mark is. Playing on another level. Everyone else still trying to figure out what master cylinder to use.
Mike Redpath
Musclerodz & Customz
facebook page
The Following 5 Users Say Thank You to Musclerodz For This Useful Post:
130fe (05-25-2020), camcojb (05-25-2020), dhutton (05-25-2020), eville (05-25-2020), fleet (05-25-2020)
  #390
Old 05-25-2020, 01:08 PM
Stielow's Avatar
Default Camaro LT5
Porsche Calk White ?
Stielow Engineering
The Following 3 Users Say Thank You to Stielow For This Useful Post:
streetbird (05-25-2020), syborg tt (05-29-2020), WILWAXU (05-25-2020)
