Got upper control arm mounts made and car back down on its feet.Used the adjustable slugs in upper mounts like they use on stock cars to adjust roll center,worked out pretty good but man are those 4th gen Camaro uprights tall.Ron
Wanted tires all the way out on the edge.Ended up cutting fenderwell lip completely out of new fender,bulging wheel opening about 3/4" in criticle areas for clearance.Then I formed a peice of 1/4"round bar to the shape of the wheel opening and welding it in place.Turned out real well,275/40-17's on 17x9.5 wheels,on the front!.Man those big meats look cool.Ron
looks great, i did that on my car as well, however i used some 1/8 bar, worked killer, do you have full turning radius at that ride height? what size front tire? could you tell me the rocker height to the flat part of rocker and also height from ground to bottom of subframe below car? thanks alot, looks nice
The front tires are are 275/40-17's,and clear everything even when fully depressed,the subfame I made myself and I wanted nothing lower th 5",so it stayed at 5",I would amagine the rockers are at about 6",but I'll measure tomorrow.Ron
