Old 02-07-2008, 03:12 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default G-Bar suspension with Moser M9 housing
Well it took some time and a lot of phone calls, but I've finally decided what rear suspension is going into the 68 Acadian. I was originally going to go with leaf spring/ladder bar set up but was quickly told that was not the way to go. I was then looking an AME rear clip set up, but don't want to cut my entire trunk out. I wanted something easy to go with. After many phone calls to Frank at http://www.prodigycustoms.com/ I have ordered an Alston G-Bar set up with QA1 shocks instead of the Varishocks as I already have QA1's in the front and want to keep them all the same. I also have coming a Moser M9 housing with back brace and Moser 31 spline axles. And I have some money left over to buy new rear wheelhouses. In the front I already have Speed Tech upper and lower control arms with the QA1 coil overs. In between will be a 427 sbc 500+ hp and a TKO 600 with 18" Foose Nitrous II's on each corner.
I highly recommend giving Frank a call. He was very patient with my million phone calls and questions and made a number of calls on my behalf. Thanks again for everything Frank.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
