Old 06-28-2013, 04:26 PM
69greyghost 69greyghost is offline
Default 4 piston in the front 1 piston in the rear on a gen 1 f body, any advice?
Hey guys I recently came across a set of 2010 camaro rotors and calipers that I intend to use on my gen 1 f body. After some research I discovered flynbye.com and got some good insight on what my options were. I can run the brembos all around but I will not have a parking brake, seeing that my car is a manual right now that wont work. My next option according to flynbye was to use the brembos in the front and use ls brakes in the rear. My car is a 69 camaro and currently has disc front and drum rear, both are stock set ups. I guess my question is can I run the 4 piston brembos in the front and use the ls style one pistons in the rear without any issues because of the differences in pressure, how will my offset change, and Do I need some type of bracket for the rear or do they just bolt on? I looked in the brake threads and didnt see any info on this, ls1tech had some info but none on brake conversions for a gen 1 f body. I appreciate any and all insite guys, thanks in advance.
