Old 02-01-2015, 10:04 AM
Stielow's Avatar
Stielow Stielow is offline
Things are moving forward.
Thomson finished the short block so we will swap of the top end and the engine will be ready. Bran has the same engine in his Vett and on E-85 it cleared over 1000 HP.
Across town Sled Alley has a good start on the vehicle modifications. Matt and I really like the way the under hood looked and worked on Hellfire so we are sinking the dry sump tank in the cowl again. We added a little more oil volume this time. The system should be 16 quarts when we are done. We are going to make an access in the inner fender so we can service it this time.
We are filling all the odd holes in the firewall and welding up the bars that pass through the fire wall. They always rattled.
Matt should have the transmission cross member done this week.
We should have the new radiator from C&R in 2 weeks. Once we get that we can finish the engine bay.
The car is moving quickly because we have a plan and we have done it before:
Sled Alley List
Fabrication work stage 1
• Fill all the unneeded holes in the firewall and the bottom of the car
• Move the dry sump tank to the cowl area
• Make air oil separator / goiter tank (New design)
• Make trans cross member (Like Hellfire)
• Make the passenger inner fender well 2 pieces to allow access to the dry sump tank
• Rework the shelf in the back seat area
• Make dip stick hose
• Mil Spec fire wall pass through (Like Hellfire)
• Mil Spec rear pass through (Like Hellfire)
• Mount intercooler pump (Like Hellfire)
• Mount ABS module (Like Hellfire)
• Mount ECM (Like Hellfire)
• Mount fuse box (Like Hellfire)
• Move harness bar up 1.5 inches (Like Hellfire)
• Modify Detroit Speed Dash for kick up and add aluminum removable panel (Like Hellfire)
• Remake front down bars
• Modify inner fender wells to clear down bars
• Rear package tray speaker holes 6X9
• Dash 2 4” speakers
• Make ½ inch fuel line
Car comes back to my house
Stage 2
• Mount radiator (C&R is making) ETA 3 weeks
• Make air inlet tube
• Mount air filter
• Rework hood for stock hood latch
• Rework rad support for stock hood latch
• Modify exhaust to connect to new headers and old exhaust
After Stage 2 I envision blowing the car back apart to do the paint work.
Stage 3
• Repaint bottom of car and firewall
• Repaint trunk
• Repaint outside mirrors
• Repaint front bumper
• Touch up roll bar
Car back to my house to plumb it and wire it.
Stage 4
• New carpet
• New recovered back shelf
Stielow
