Old 10-19-2016, 06:44 AM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Originally Posted by MillerBuilt View Post
C6/C7 Hybrid Floater System -
[SIZE="4"]Installs onto GM 10/12 Bolt (except Impala or Truck)[/SIZE] rear-ends,,,,, BOLT-ON!
That's right, you can use your current GM 10/12 Bolt rear-end housing, NO welding & simple installation!
Advantages:
  • Bolts to GM 10/12 Bolt housing end / brake flange (except Impala or Truck)(Big Ford application also available! https://lateral-g.net/forums/showthread.php4?t=49657 )
  • Eliminates the weak/dangerous factory c-clip axles
  • Reduces/eliminates brake “knockback”
  • Eliminates axle deflection
  • Wheel & tire remains intact should an axle failure occur
  • Front or Rear Caliper / E-Brake Cable Positions
  • Utilizes the robust, zero maintenance C6/C7 ZO6 Hub Bearing Unit
  • Utilizes OEM C5/C6/C7 Corvette, and 5th Gen Camaro brake kits
  • Utilizes aftermarket C5/C6/C7 Corvette, and 5th Gen Camaro brake kits
  • Utilizes your existing BAER / WILWOOD caliper & rotor (some restrictions apply)
  • Super compact design compared to traditional style full floaters
  • All advantages of a traditional style full floater without the maintenance
  • Replacement parts available at local GM dealer or local parts house
  • No modifications required to the hub bearing unit as other kits in the marketplace
Note: this applications will add 1/16″ per side to your existing wheel mount surface (based on an existing 2.810″ axle/brake offset)
Fitment: OEM 10/12 Bolt Rears: 67-81 Camaro, 64-72 Chevelle, 64-74 Nova
GM 10/12 Bolt Bolt-On “Base Kit” (pictured below)
GM 10/12 Bolt Bolt-On “Base Kit” (pictured above)
Base Kit Includes:
• (2) Billet Steel, C-Series, Hybrid Floater Adaptors
• (2) Billet Aluminum Caliper Brackets
• (2) C7 Corvette, SKF 33 Spline Hub Assemblies
• (1) Install Kit
• (2) Hub Spacers
• (2) Billet Aluminum Hub Cap Seals
________________________________________
PRICED AT - $1498.00
Add Axles - $400.00
• (2) Hy-Tuf Full Float Axles
Add E-Brake items - $325.00
• (2) C5/C6 Corvette Complete E-brake Assemblies
• (2) C5/C6 Corvette Parking/E-brake Cable Brackets
Have interest?
Have questions?
Need more info?
Dealer Inquires Welcome!
Below pics of the assembled "Base Kit".... (attached 10/12 Bolt End is for display purposes only)
Below pics shown with optional C5/C6 E-brake Assembly & E-brake Cable Bracket. These two e-brake items are optional and the system can be run without and added at a later date if desired.... (attached 10/12 Bolt End is for display purposes only)
Few pics below of this 10/12 Bolt Kit in action!
In Stock!
