Old 08-23-2008, 04:21 PM
deuce_454's Avatar
i would love to see the kinsler cross-ram IR setup in that test.... and possibly a fast92 and OEM l92 intake....
Jake: Hit it.
Old 09-08-2008, 07:51 PM
Van B's Avatar
Van B Van B is offline
I assume you were talking about this one.
http://www.kinsler.com/NewProducts/P..._CarbonWeb.jpg
I like it. Anyone have any idea on pricing? I am willing to give up a little power for some wow factor when you open the hood, so I don't need the on that makes the most HP. How about driveability? What ECU would you use?
Also, some say a MAF system is better than speed density. Opinions?
Jeff
99 Miata LS6
67 Camaro Street Fighter 599 HP L92-SOLD
Old 09-09-2008, 05:24 AM
XcYZ's Avatar
XcYZ XcYZ is offline
It's around $6k. Kurt is building a 69 Camaro right now with the Kinsler intake on an LS7. The car is almost identical to mine, (same cam, trans, rear, etc). It will be chassis dyno'd at the same shop that did mine, so it's going to be interesting to see what kind of numbers it makes.
There's a bunch of pics here:
https://lateral-g.net/forums/showthread.php4?t=15999
My LS7 69 Camaro
Old 09-27-2008, 09:51 AM
FreddyG FreddyG is offline
Wilson also makes sheet metal intakes. If doing a comparison, you might want to check them out too.
Also, if you want one of the coolest intakes around, look at a Harrop. They're a company from Australia and their intake has 8 individual throttle bodies and is just SICK.........but be sitting down when you price them!
Harrop Hurricane............
Good Luck! It sounds like a Cool Project!
Old 09-27-2008, 10:58 AM
deuce_454's Avatar
id like to hear about the drivability and idle of the IR manifolds aswell... and if somone could post a dyno clip with sound ;-)
Jake: Hit it.
Old 09-27-2008, 11:24 AM
Datsbad's Avatar
Datsbad Datsbad is offline
Driveabiltiy on Fuel was great . The harrop made by larger camshaft very smooth . Pretty common on the IR set ups.
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
Old 09-27-2008, 01:14 PM
Originally Posted by Datsbad View Post
Yeah , we did that on Fuel back in 05 .ACTUALLY CHEAP COMPAIRED TO SOME OF THE OTHER INTAKES OUT. Worked great and provide much more power than a standard LS style intake
That car is SICK! You did a Beautiful job on that! Could I Please ask what something like that sells for?
From the sound of it, if you can get the tune of the separate throttle bodies right, it has Wicked throttle response!
My guess would be that quite a bit of drivability is in the tune. That's regardless of intake, but some intakes might make it easier to tune, that's just my guess.
Here's one that I found on youtube of a 454 LSX motor running a Beck sheet metal intake! This thing sounds Absolutely WICKED!
LME 454 LSx MONSTER..........
Old 09-27-2008, 11:20 AM
Datsbad's Avatar
""DEMON"
6.1HEMI/TKO 5 SPEED
Mini tub/AIR Ride
RMS Suspension
