Originally Posted by Teetoe_Jones
Got any more detailed specs?
How much negative camber gain in degrees per inch of travel?
What is your total bumpsteer figure? (don't even think about saying zero)
What are your recommended alignment specs for street? How about a race setting?
What is the widest front tire you can run on the frame?
Tyler
Hey Tyler,
Camber gain is -.68 degrees per inch
Bumpsteer .030 inches @ 1"
street set up- minimum 3 degrees caster, -1/4 degree camber, 1/16 toe out, with a 1" swaybar
race set up- minimum 5 degrees caster, -1/2 degree camber, 1/16 to 1/8 toe out, with a 1 1/4" swaybar.
Also I checked out your site and looks like you have some really nice products yourself. Looking forward to share some info with you.
