Old 05-09-2009, 09:00 AM
asifnyc's Avatar
asifnyc asifnyc is offline
Default ez kit
I'm in the process of re-wiring my '73 AMC Javelin with the EZ wire kit. I looked at the prices of the painless and AAW kits and cheaped out
my car is completely non-stock; aftermarket gauges, no hvac, power door locks/trunk popper, moved the dimmer switch to the turn signal stalk, etc, etc...
as Rhino stated above, the AAW direct fit kits will come with all the factory style connectors so you can just mount it and start plugging things in. the EZ kit requires you cut and terminate the ends as needed. again, that was fine for my situation but might not be what you want.
the EZ wire kit comes with the following, pre-terminated, connectors: gm style ignition switch, floor dimmer switch and the steering column connector (for the steering column you have to actually plug the wires into the correct connector for your car but they just pop right in). that's it. every other wire will need to be terminated by you.
for my purposes the ez wire kit does the job. the only thing I'm not happy about is that it's not a "bulkhead" connection setup. What I realize now is that I would have preferred to pay for a fuse block/engine harness that connects through the firewall and "sandwiches" together (like a stock setup). the ez wire kit engine harness is just fed through a hole you drill in the firewall). I believe some painless kits have a fuseblock/engine harness connector that sandwiches together like a stock unit and I assume the AAW kit's as just like stock...
there are some pics/posts on my install of the ez kit (still not done) on my blog (see my sig). good luck.
oh, one other comment about AAW that has nothing to do with their product quality... I HATE their website... makes my eyeballs melt. drives me crazy when people try to get "creative" with websites. just make a site that's easy to read and navigate... just my .02 cents.
-asifnyc- penngrove, ca (SF bay area) asifnyc.com - Javelin Blog
1974 AMC Javelin NASA American Iron road race car
1974 AMC Matador road race project
1975 AMC Gremlin shell
1973 AMC Javelin/AMX - street
1975 AMC Gremlin - street
1970 AMC Javelin shell
1962 Rambler American vert
