Old 10-16-2005, 05:51 AM
rocketrod rocketrod is offline
Originally Posted by slck6t9
... What front backspacing would be best, 4.75 or 5?
If you are custom ordering the rims/BS I would go with 4 7/8" which is what DSE recommended when I ordered my Budniks from them. If you can't specify a specific BS then go with 5" BS as you can always add a spacer, but your stuck if you have clearance issues with 4.75".
Old 10-16-2005, 06:00 AM
XcYZ's Avatar
XcYZ XcYZ is offline
When I had 17's, I used 4.75" of BS with a 245/45, it worked great.
My LS7 69 Camaro
Old 10-16-2005, 09:33 AM
slck6t9's Avatar
slck6t9 slck6t9 is offline
Thanks guys. Scott what size rims did you run on back with your 17's? I want the 17 x 9 1/2 but I have drums and don't know when I can afford disc. Jody said the 5.5 bs would work but might rub until I can put disc's back there. If I'm only about to keep the drums would that b.s. still be ok or what shout it be. Just want to get all my ducks in a row before I order new wheels. Again guys thanks for taking the time to help. I just want to get it right.
Old 10-16-2005, 09:49 AM
130fe 130fe is offline
Scott, I have the 9.5 on the back with drums (until this winter when the LT1's go on) and I have no problems at all.
How's schoolhouse life going there? Heard Jack Orrell is going there? PM me if you get a chance.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 10-16-2005, 12:20 PM
Datsbad's Avatar
Datsbad Datsbad is offline
depending on the wheel you are getting i would have a custom set bulit also at 4-7/8 also thas what i run on my budniks
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
Old 10-16-2005, 02:52 PM
slck6t9's Avatar
Thanks guys. Chris what is the b.s on your rims? Datsbad, is that 4- 7/8 on the front or rear. I am going with the Centerline Sundance retros.
Old 10-16-2005, 03:13 PM
Scott, I am running 4 3/4 BS on the front (17x8) and 5.5 BS on a 17x9.5 rear wheel. Datsbad is referring to the front BS 4 7/8. I think there are some minor differences in the 67-8 and the 69 wheel housings. What brakes are you running on the front? Do you have factory disks or do you have a C4/Baer set up? I know there are differences on the "track width" (think it is called) with the drum and disk spindles hubs. The disk style put the wheel about 3/8 inch further out than the drum hub. I would base my wheel offset on ones that are similiar to the one that you are going to use. Datsbad and Scott can give you better info on the 69 stuff better than I can. Hope this helps you.
Chris
1968 Camaro SS
LS3/T56
Old 04-06-2006, 08:20 AM
Fastbowtie Fastbowtie is offline
Default Well how did they work?
Hey Scott I'm new to this form and read your question and all the replys to it. My question is how did the wheels work out? Thanks.
