Old 06-24-2009, 08:05 AM
KTrostel KTrostel is offline
Default Newbe Front Suspension ??'s - Second Gen F body
OK, I have looked through the posts, and gone to the vendor sites but have been left a little let down interms of content - So here goes
I have a 78 TA, I have already welded up the stock front sub frame. Ideally I would like to use the AFX tall spindles (checking on availability) with good tubular upper and lower control arms. Short of that, I would substitue Howe tall ball joints along with good upper and lower tubular control arms. My problem is the control arm vendors that I have looked at - SC&S (globe west), DSE, Guldstrand, and Hotsckis, none come out and quantify the camber gain or bump steer correction. All say they have increased camber gain and decreased bump steer but to what extent. I find that it is impossible to measure one against the other without some quantifiable values.
Any insight would be greatly appreciated.
Kurt
Old 06-24-2009, 08:33 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Welcome aboard, Kurt.
Those are great questions. And as far as being quantifiable, do you know the camber gain of the stock suspension setup (at a known ride height) for the benchmark? I don't know those numbers and I think this could be a great thread for getting that data posted.
Bumpsteer can be measured and dialed down to a minimum with the right tools (barring any major issues and crazy low ride height). I've done that on my car using a Longacre bumpsteer gauge and a set of Baer Trackers.
My LS7 69 Camaro
Old 06-25-2009, 08:09 AM
Thanks for the help with bump steer.
As for the camber gain, it is my understanding there is no camber gain with the original design. Of course that is a gross average not a precise measurement.
Anyone ???
Old 06-25-2009, 09:54 AM
Blake Foster's Avatar
No tubular control arm (that i know of) is going to change bump steer. unless the arms are shorter or longer, as for camber gain the only way to change it is to relocate the control arm mounting point (guildstrand mod on first gen)or the ball joint pivot location so tall ball joints or ATS Tall spindles. you would never know the differance on a street driven car.
have a look at our arms, i noticed you missed them in your product search
http://www.speedtech-performance.com...prod/prd57.htm
http://www.speedtech-performance.com...prod/prd58.htm
here is a pic of one that we did with the complete set up
Blake Foster
www.speedtechperformance.com
Old 06-25-2009, 12:41 PM
Ultimately I would like to take the car for some track days.
Thanks for the link. Tell me, do you offer a package with coil overs?
Old 06-25-2009, 08:25 PM
we offer the QA1 coil over conversion set up.and in the package there is some monry to be saved.
give us or one of our dealers a call.
Blake Foster
Old 06-30-2009, 12:54 PM
pro-tour79's Avatar
pro-tour79 pro-tour79 is offline
Supporting Vendor
as mentioned the A-arms themselves will not change bump steer or neg. camber gain unless the pivot to ball joint points have been changed and the length of the upper arms has been changed, remember that second gns already have "tall spindles" no real reason to change them, we have a Comp upper control arm and tall ball joint that will correct most of the second gen's short commings, the second gen has very good geometry to start with and only needs small changes to make it better.
The stock lower arms can be retained but should get solid bushings, either Delrin or sphericals but should get some welded braces to limit flex we do have a new lower control arm that is designed to limit flex, has 2* built in caster and saves 3 lbs over stock.
www.pro-touringf-body.com
Old 06-30-2009, 07:42 PM
Cread01 Cread01 is offline
I have a 78 camaro and am currently doing some of the same things. I went with the qa1 coilover setup, the scandc stage 1 kit with the howe tall upper ball joints tubular lower control arms and the true steer kit from pro-touring fbody. there are tons of options out there and I looked at them extensively to get what I wanted.
For me alot of it went on what I could get in my budget and what I liked about certain products. I really liked the spc control arms because of the adjustability without shims but they do have an industrial look. personally I like that about them. SCandC.com is a sponsor here and marcus is extremely helpful and knowledgeable. Dave at protouring fbody was also extremely helpful he is a sponsor here also. That is not to say it's the best option for you just the way I went. That is one of the best things about this site is that you can talk with alot of the vendors and they are usually very helpful.
If I would have known that killer customs would give a package with control arms and coilover's I may have went that route to save some bucks also.
If you do a search on nastyz28.com there are tons of posts about what other people have done on there second gen's and that may be helpful also.
Old 07-01-2009, 12:54 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
Originally Posted by pro-tour79 View Post
...we do have a new lower control arm that is designed to limit flex, has 2* built in caster and saves 3 lbs over stock.
Dave showed me one of these over the weekend. Nice. The added caster is a plus. I run 6* in mine and I get some rub in the RF.
Scott from NJ
Old 07-06-2009, 11:13 AM
Great info. I will definately take a look at these suggestions.
