Old 01-20-2010, 10:23 PM
jhiphopjunky's Avatar
jhiphopjunky jhiphopjunky is offline
Default 70-72 Chevelle Mini Tub
Im thinking about mini tubbing my 1972 chevelle.
I know you can fit an 11in wheel under the back without a mini tub but i want to go wider, 12 maybe 13in in the rear.
Can anyone help me with some info as far as what it would take to make it happen.
1. Does anyone make a tub well (like a dse)
2. Do need to narrow the frame.
3. Do need to narrow the rear end.
4. Do i need to narrow the gas tank.
5. If i decide to go with a shop roughly how many hours would it take for a shop to do the job.
Any other info you guys have to add about a mini tub for my chevelle would be greatly appreciated.
Thanks!
Old 01-20-2010, 10:37 PM
BritishGreen68 BritishGreen68 is offline
I dont know of a company that makes them but im sure they must be out there, from what i understand you have to do some pretty serious frame notching to make room..
heres some info.. http://www.chevelles.com/forums/showthread.php?t=253102
heres a pic i found of a frame after making room for the mini tub on a chevelle..
Chris
Under construction-British Green 68 Camaro-
Old 01-21-2010, 03:06 AM
deuce_454's Avatar
Thanks!
1:no
2:no
3:no
4:no
5:no
atleast if you want to retain the oem frame... then you are limited to notching the frame "to the seam" .. the wheels just need more offset to pull the inner lip inwards.
if you want alot more, then you are propably best off getting an aftermarket frame, if you retain the stock one you will have a couple of grand into both the front and rear suspension, some into strengthening and boxing the stock one to get close to what an art morrisson frame with 3 link and c6 front suspension can do....
I went stock frame with my g body (simmillar frame, but narrower) and it wasnt cheap to remove, blast, modify, paint and install suspension (ats spindles, GW front controllarms, currie rear arms, wattslink, moser rear, varishocks etc... and its still a stock frame limiting how low i can get the car, how wode tires i can run etc.. but its up to you in the end
Jake: Hit it.
Old 01-21-2010, 05:33 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Thanks!
1. No.
2. Depends on how wide of a tire/wheel you want.
3. No, but wheels with that much backspacing won't look good.
4. Maybe, depends on if you move the framerails in.
5. I did mine, but didn't keep track.
Also, post like these should go in the correct area.
Old 01-22-2010, 06:07 AM
rallye455 rallye455 is offline
I just did my 72 442 (has the same wheelhouses as the Chevelle) and I couldnt find anyone that makes a kit for them. What I did was buy a set of replacement inner wheelhouses and cut the stock ones out leaving 2" of them still in the car and cut the new ones to fit(gained 2") and welded them together. I also had to notch the frame alot to get the added clearance. The only problem with doing it this way is the wheelhouses are rounded in the corner so it will not allow you to run a really tall tire. I didnt care about height so it wasnt a big deal to me. I have a set of 345-40-17 on 17x12 wheels.
Old 01-22-2010, 03:12 PM
Nick.V70's Avatar
Nick.V70 Nick.V70 is offline
jhiphopjunky, I'm with you on the wide wheel under these cars. Been poking around the forums trying to gather info for my car. Really I thought I would want more but a 11" wide looks pretty sick. Here was a pic posted on one of my threads 70' Chevelle largest rear tire/wheel combo ????
Originally Posted by slownova View Post
19s front 22s rear. air ride. big block SS car bunch of custom stuff...
if u want pics of anything special let me know i got hundreds. just didnt want to ruin your post
I saw your wheels for sale, did you sale them already?
Nick's 1970 Chevelle project - '70 SBC 383 Stroker - Rushforth Rated X wheels - 14" Wilwood - Anvil Carbon Fiber hood/deck lid - Fesler billet - Corbeau Sport Seats, and still building....
YouTube & Chevelle pics - Instagram @nick.v70 & @ChevelleFactory
Old 01-22-2010, 04:22 PM
HOLOHAN'S HOT ROD SHOP's Avatar
HOLOHAN'S HOT ROD SHOP HOLOHAN'S HOT ROD SHOP is offline
DSE doesn't offer a mini tub kit. It can be done, but takes a lot of work. More than a standard Camaro/Nova install.
Old 01-22-2010, 04:32 PM
We have done a couple of them. To fit 335s / 345s...............
1. Does anyone make a tub well (like a dse) now, add a 3" strip
2. Do need to narrow the frame. Yes, about 6" to be safe
3. Do need to narrow the rear end. No but if you want a deep lip wheel, yes you will narrow the rear. We have all the math available
4. Do i need to narrow the gas tank. No
5. If i decide to go with a shop roughly how many hours would it take for a shop to do the job. It requires a aftermarket coil over conversion and crossmember, we use a QA1 kit. Finished and ready to paint, about 100 hours
Frank Serafine
Old 01-22-2010, 10:29 PM
Nick- I still have my wheels. I got a few bites but I haven't sold them yet.
Pm me your number if your interested in them.
Frank- wow that sounds like some major fab work at 100 hours. Do u have any pics you can post of any of the chevelles you mini tubbed?
Old 01-23-2010, 03:14 PM
The WidowMaker's Avatar
like others have said, the tubs on a 70-72 are about even with the frame. that means that both have to be worked. but really, a 305 or 315 will fit with little to no work, or a ton like mine (depending on how much you want it lowered and how tall of a tire).
Tim
"The WidowMaker"
