Old 04-02-2010, 08:49 PM
Did you check the woodward site out? They also have weld on couplings. maybe you can trim a little off that flared end and put a weld on coupling over it? You can allways try calling him and asking if he has something that will help you out.
Old 04-03-2010, 07:27 AM
GM Muscle's Avatar
I did consider that. We have a local smileys performance(speedway) so I figured if I got a little bit of dd shaft I could put it in about 6 inches into the stock shaft and use plug welds. Similar option to Woodward but cheaper and parts are pretty much in house( no wait). I like the idea too because the column will still remain it's "collapse" feature if I ever nail something head on.
I'll keep this updated that way there's at least a reference for the next guy. Thanks for the help guys
'69 Camaro- Daily Driver
'70 Chevelle- Project
Old 04-05-2010, 02:47 PM
LM7_67 LM7_67 is offline
Originally Posted by Rybar View Post
That is quite strange why yours is flared.
I had the same problem, header tube was hitting the rag joint so I installed a Borgeson U-joint:
Borgeson U-joint 13/16"-36 spline & 1"-48 spline
Is that the size needed to replace a stock rag joint on a first gen?
1967 Camaro - LM7, T56, TVS, 12.7:1
1996 Impala SS - DD
Old 04-05-2010, 06:00 PM
Rybar's Avatar
Rybar Rybar is offline
That's the size I needed, I would definately measure yours first as I am not sure if mine is stock or not.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
