Old 07-17-2010, 06:07 AM
Sorry - saw that you already looked into the shorty plugs...
Fingers took over the brain. It happens all the time...
Old 07-17-2010, 08:56 AM
Musclerodz's Avatar
What wires are you running? i have had taylors touch headers and not melt.
Mike Redpath
Musclerodz & Customz
facebook page
Old 07-17-2010, 11:31 AM
thedugan's Avatar
thedugan thedugan is offline
Accel 8.8 wires
Just found a set of Dse plug wire protectors I had sitting around. Rated to 500 degrees. Not the best but I'll try it
Doug L.
68 Camaro RS/SS Conv. LSA/T56
67 Camaro RS LS2/T56 "NutKse"
Old 07-17-2010, 08:31 PM
Musclerodz's Avatar
I have seen accels melt. switch to taylor or msd
Mike Redpath
facebook page
Old 07-18-2010, 06:47 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
What degree ends are you using?
I've found using the Taylor 135* ends usually work best.
If all else fails, and your ends are directly on the header tube, take some header gasket, cut it into small pieces, and wedge it between the plug end and the tube. The more you can get in there the better.
Old 07-18-2010, 05:30 PM
I can't believe a guy with as beautiful of a car as you have just wrote that!
Old 07-19-2010, 07:14 AM
MarkM66's Avatar
My plug wires don't hit my headers.
I guess I should of just told him to get a set of $2000 Lemons headers. Money may be no object to you Greg, but it is to some.
I guess my suggestion is so "rigged" huh? So some small almost non visible pieces of insulation is so much worse then some big insulating boots? Gotcha.
Don't you have some cool ball milled valve covers or Torque Thrust wheels to polish?
