Old 12-02-2010, 08:56 PM
The WidowMaker's Avatar
i had the 12 bolt narrowed with 9" ends, straightened, blasted, gears assembled and custom axles and bearings made for under 1k from currie. the axles were about 450 by themselves and the gear assembly was 100 so just the narrowing wasnt too bad.
"The WidowMaker"
