Old 01-24-2011, 02:54 PM
Sieg's Avatar
Sieg Sieg is offline
What components of the suspension binding is he refering to?
I agree the rear is a little high, is compouned by the front being a little low?My car is about .75-1" high in the rear...........I can definitely relate to the dissatisfaction.
Cannon Racecraft should be able to make custom springs if coil bind is the part of the issue. http://www.cannonracecraft.com/ if the shock length/travel will accept it.
Hopefully it's not linkage geometry.
Old 01-24-2011, 03:13 PM
Rybar's Avatar
Rybar Rybar is offline
He says it's the linkage bar geometry that will bind. Going to a shorter shock or spring would create this.
Looking at Todd's G-bar his car is sitting lower than this, but the G-link is a little different.
I'm going to wait and let the springs settle and then see how it sits. Should have it back this week.
Frank told me this kit could be dropped quite low, but maybe he wasn't exactly correct. I'd like it as low as the DSE setups most guys run.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 01-24-2011, 03:39 PM
Hmmmmm... I can't tell from the photos, are the coil over mounts bolted in at the lowest position? The pinion angle will also effect the ride height. As the pinion is pointed down, it naturally jacks the rear end up. Your shocks should bottom out before any type of binding happens. It wil settle, not enough. Is all the weight in the car?
Old 01-24-2011, 04:14 PM
Rybar's Avatar
Hey Todd, weight is in the car. Yes the shocks are in the lowest position. I just spoke to Bill. He's going to rebuild the upper shock cross member to raise the shock and lower the car more. I'm picky about the stance. This kind of sucks had I known I would have gone with the DSE kit but at least it will get the car sitting where I want it.
1969 CAMARO RS
Old 01-24-2011, 04:17 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Hope it all works out for you Ryan. Good luck.
Old 01-24-2011, 04:26 PM
Sieg's Avatar
No argument here, the stance has to be right! Good luck.
Old 01-24-2011, 04:30 PM
I agree, stance is a big deal. Looks to need to come down 1". What is the measurment from the ground to the body crease in line with the axle?(Guessing 25.75) I'd wait for Frank, something is not right.
Old 01-24-2011, 04:32 PM
Rybar's Avatar
Oh everything will be fine, it's only going to cost a little more in labour. Come this far what's a little more
Remember Todd the G-link is a slightly different kit than your G-bar. The shocks sit more upright rather than canted inwards.
1969 CAMARO RS
