Old 03-28-2011, 03:36 PM
Track Junky's Avatar
I think the front stance looks good. I would definitely drop the rear. Direct side view looked good but lengthwise side view looked like the rear was a bit high. IIRC I think I am 23 1/4" to fender lip all the way around.
BTW, car looks great!
"EDIT"......Here are some pics.....
Gaetano Cosentino
Old 03-28-2011, 05:46 PM
3SuperSports's Avatar
3SuperSports 3SuperSports is offline
Looks great to me.
Old 03-28-2011, 07:40 PM
Sieg's Avatar
Sieg Sieg is offline
It's my understanding that using more than 1" of block is not recommended? I could see going 1.25 and still have the top leaf inside the perches. The other option is to de-arch the spring? I don't think there is any room to go lower in the rear shackle.
Maybe the 1.25" block and a two 100lb bags of sand in the trunk would get it close.
Thanks for the BTW.
Old 03-28-2011, 07:54 PM
19,69camaro 19,69camaro is offline
First off your car looks great with the blacked out trim and vinyl top. I don't see many that dont look like a grandpa's camaro. As far as ride height is concerned i think with a 1/2 inch drop in the rear it would be spot on.
Old 03-28-2011, 08:03 PM
Sieg's Avatar
Thank you.
I'm not much of a vinyl top fan but on this car it doesn't bother me.....much.
It those pics the car has about 10 gal. of fuel. The rear springs are very stiff so 5 gals/40 lbs isn't going to drop it much. I'm thinking .5" is money, .25 acceptable. The challenge is how to safely obtain that .5".
Old 03-28-2011, 08:38 PM
lhkustoms's Avatar
lhkustoms lhkustoms is offline
You can run a 1-1/2 block and you'll be fine. Dave (flash68) has 2" blocks and runs the car hard. Just make sure your blocks have the locating pin/hole in them
Luke Mau
L & H Kustoms
Old 03-28-2011, 08:59 PM
Blake Foster's Avatar
i think it looks good
just change out the rear suspension with your "Present Plan"........... and it's all good.
if it was mine i woud go 1/2 to 3/4 front and back.
my .02 keep the change.
Blake Foster
www.speedtechperformance.com
Old 03-29-2011, 11:57 AM
Sieg's Avatar
You know how bad I WANT to!
Thanks.
Sieg's Avatar
Luke,
Thanks, I can get solid blocks of rem material cut locally and install locating pins.
What about the stock 7/16" dia U-bolt vs stepping up to 1/2"? I'm assuming bigger is better in this case. I have new DSE Shock Plates, they are for 7/16 u-bolts, enlarging the holes to accept 1/2" shouldn't cause a problem?
Old 03-28-2011, 09:52 PM
Rybar's Avatar
Rybar Rybar is offline
I think it looks pretty good as is, but maybe yeah drop the rear 1/2" more.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
