Old 05-05-2011, 01:14 PM
BANKO's Avatar
BANKO BANKO is offline
Thanks guys for all the great suggestions on other concerns.
1. jacking the car
2. oil pan clearance
3. header / exhaust routing
4. crowned roads
I'm looking to avoid this donk look (22s shown, I will run 20s):
The bigger concern I have is even if I run Speedtech upper and lower a-arms + dropped AFX spindles, I will get have some steep a-arm angles & possible ball joint bind if I can not raise the upper & lower a-arm mounting points to try to make the a-arm parallel to the ground.
This pic shows the cross member touching the ground w/ airbags deflated on another car and steep a-arm angles.
Josh
Designing a '65 Chevelle with a StreetFighter theme, inspired by JP's II Much & Ron Schwarz's $5k Mustang
