Old 08-15-2011, 09:43 PM
montanass's Avatar
montanass montanass is offline
Default poor handling on highway
so i'm getting tired of chasing my car around going down the highway. It seems to jump from one side of the rut(s) to the other, making it quite a handfull and takes away from the fun of driving.
My setup is:
69 el camino
BBC- 2" lowering springs, stock spindles, 18x8 front rims 255/40R18 (f)- 18x10 295/35R18 Rear
all hotchkis components, sway bars, lower conrtol arms (rear) edelbrock adjustable upper control (rear), etc.
I'm just wondering if this is common with larger wheels and low pro tires, or if i should start looking into this a little deeper.
thanks
'69 el Camino 409BBC-wanna B G machine
Old 08-15-2011, 10:17 PM
a bit more info needed;
alignment specs?
brand of tires being used?
steering linkage new or old? worn components
steering box new or old? worn components
tire pressure?
what speed?
front suspension new or old? worn components
Old 08-16-2011, 05:56 AM
wmhjr wmhjr is offline
thanks
No, it is not common.
Old 08-16-2011, 03:48 PM
sweetstang68347's Avatar
sweetstang68347 sweetstang68347 is offline
A couple of thing that come to mind are the amount of caster in alignment and bump steer. But yeah...
alignment specs?
tire pressure?
what speed?
Old 08-16-2011, 11:25 PM
montanass's Avatar
Tires are toyo t1r, 28 psi, alignment is set to "factory specs" (had it done at les Schwab). Steering components are factory origional. I have a poly bushing kit in the plans, and tubular upper and lower control arms. I've been waiting to do the bushing kit until I get the control arms since I'd have to do those bushings anyway. Also a quick ratio steering box is in the plan book... However since a new house and other things are taking up most of my fun money I have to be patient.
Old 08-17-2011, 06:30 AM
Bryce Bryce is offline
Dont quote me on this. But weren't the factory specs set up for bias ply tires. I know the 65 falcon mustang specs were for bias ply tires.
What are the factory specs. I bet you have very little caster, (the reason you bought the tubular control arms was to increase positive caster). I would also guess you have positive camber. You want the tire to be in at the top, that would be negative camber.
Old 08-17-2011, 09:30 AM
There's your problem. Factory specs are worthless once you've changed geometry using different spindles, ball joints, upper and lower control arms. You've changed your entire front geometry and need to align accounting for it.
Old 08-17-2011, 09:42 AM
Proforged Proforged is offline
Since he hasn't changed his spindles or ball joints, the front end geometry is the same as stock.
At the minimum, I would recommend replacing all of your control arm bushings, the idler arm, pitman arm, tie rod ends, and center link. Tall Upper and Lower Ball Joints will allow you to run a more aggressive alignment, but you will likely need tubular upper control arms to get the positive caster you need for highway handling.
If you install tubular upper control arms and tall upper and lower ball joints, here are some alignment specs you can use:
Camber: -1/2 degree
Caster: +5 to 5.5 degrees
Toe: 1/16" total toe-in
If you can't swing the above components right now, bring your car back to get it aligned as close to these specs as possible in the meantime. Dialing in the camber and adding positive caster will help your handling situation some.
Old 08-17-2011, 09:48 AM
JKnight JKnight is offline
He hasn't changed any suspension components yet, including bushings. I would suggest replacing all your bushings and whatever suspension pieces you are looking to do, have Les Schwab do a more aggressive alignment, then evaluate the handling of the car. 40 year old bushings are going to make that car do all kinds of crazy things going down the road.
Also, why are you running only 28 psi?
Old 08-17-2011, 11:03 AM
He changed to 2" lowering springs. Geometry is changed.
