Old 09-13-2011, 10:49 AM
northwests's Avatar
northwests northwests is offline
Default 69 camaro lower control arm ball joint problem
Hey guys got a little problem maybe some of you may have had. I have a 69 camaro trying to get new lower balljoints for. None made for that car fit. Tried moog,spicer various other ones too all are too small by approximately 1/8 inch. Any input would be helpful. Thanks
Old 09-13-2011, 02:24 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Are they to small on both L and R control arms? Maybe someone modified them for a different style ball joint in the past. I've used parts store joints before, and they fit.
Old 09-13-2011, 05:09 PM
northwests's Avatar
Figured it out today. Finally talked to the right guy. Turns out the camaro being produced possibly in late 69-70 was changed to 70-81 ball joints and control arms and now sport a upgraded and much beefier ball joint. Evidently they had problems with the smaller ones used from 67-69. Thanks for the input tho. You never know what has transpired over the years.
Old 09-13-2011, 06:11 PM
Proforged Proforged is offline
For what it's worth, we've never heard of this. The 1970-81 control arms are totally different and won't bolt onto the 1967-69 subframe. I don't see how this would be possible.
Zack Kanter
President
Proforged Chassis Parts
www.proforged.com
Tall Ball Joints, Tall Tie Rods, Billet Adjusting Sleeves, and Steering Linkage Kits for Musclecars
Old 09-13-2011, 10:43 PM
David Pozzi's Avatar
Second gen Camaro ball joints use a 10 degree taper into the spindle, 67-69 use a 7 degree taper. I've never heard of this.
David
http://www.PozziRacing.com
Old 09-13-2011, 11:15 PM
northwests's Avatar
I have had this camaro for about 12 years and these are the arms that was on it. By all looks they are 69 camaro arms, they have been on a driveable car. They(new ball joint) appear to fit in the spindle as they should and in the control arm hole. I don't have the old ones they got thrown away by mistake so no comparisons. Makes me wonder now whats up since you guys are not ever hearing of this. What could be the deal. I will try to get some pics of the arms on here for you guys to look at. Thanks for all the input.
Old 09-13-2011, 11:18 PM
northwests's Avatar
The new ball joint for a 70-81camaro fits this arm and the spindle I have -I don't know whats up. Hopefully someone here can see something I do not. Thanks
Old 09-15-2011, 10:42 PM
northwests's Avatar
Nobody got any more clues to what i am experiencing. Would love to put this sucker together someday. Thanks
Old 09-16-2011, 04:21 AM
MarkM66's Avatar
I thought you said in the post above this that you got ball joints that worked. If that's the case, go with it..
Old 09-16-2011, 06:48 PM
northwests's Avatar
No i did some figuring and measuring and the 70-81 ball joint has a different length shaft by about a 1/4" and has a different taper (not by much)as described earlier by Mr. Pozzi. I have been to every parts store in my area and noone has the answer. Hopefully someone out there will read this and the mystery will be solved.
