Old 09-16-2011, 06:48 PM
northwests's Avatar
northwests northwests is offline
Originally Posted by MarkM66 View Post
I thought you said in the post above this that you got ball joints that worked. If that's the case, go with it..
No i did some figuring and measuring and the 70-81 ball joint has a different length shaft by about a 1/4" and has a different taper (not by much)as described earlier by Mr. Pozzi. I have been to every parts store in my area and noone has the answer. Hopefully someone out there will read this and the mystery will be solved.
Old 09-21-2011, 04:49 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
If factory control arms are ok, just look for some different used ones. With everyone ditching them for tubular, they should come pretty cheap.
