Old 10-30-2011, 08:18 PM
usa-69z usa-69z is offline
Default Nude Shifter pics , which one ?
I have here an aussie Ls1 tremec T56 6 speed that needs a shifter. I have looked at most shifter pics (aftermarket ) but they dont look like they have the same size bottom plate which holds shifter to box. These boxes are in the GM Ls1 commodore 2002 model and have the shifter set way back behind the housing.
Can any-one recomend a shifter that will bolt on that will bring it foward as much as possible ? Its going into a Right Hand Drive 69 camaro without a console .
any help is appreciatted .
Gav
69 CAMARO - RIGHT HAND DRIVE AUSSIE MODEL.
383 SBC 8 STACK INJECTED EFI.
RIDETECH FOUR LINK REAR - DSE MINI TUBS .
SPEEDTECH FRONT A ARMS & COILOVERS.
MOSER 3.7 REAR- 6 SPEED T56 TREMEC.
FIKSE RIMS ETC ETC..
Old 10-30-2011, 09:48 PM
68LS1's Avatar
68LS1 68LS1 is offline
Contact JHP maybe
http://www.jhp.com.au/holdenve/ShortShifters.htm
or Mal Wood Automotive
http://www.malwoodauto.com.au/
Would be same shifter as G8 Pontiac
Roger
68 RS Camaro Convertible LS1 6 speed
72 C10 SWB Stepside, old skool 350 4L60e
71 K5 Blazer 350sbc T350
Old 10-31-2011, 01:29 AM
Originally Posted by 68LS1 View Post
Contact JHP maybe
read it again , i dont want a factory shifter ,, i need one that moves it foward.
Old 10-31-2011, 05:24 AM
68LS1's Avatar
I don't know of one that moves the shifter forward like you require, but I gave you a couple of the two best contacts in Australia that may be able to help you.
The aftermarket conversions for 1st Gen Camaro appear to have created new tail housing to move shifter.
Some one in the US may have transplanted a engine & box out of a GTO who can help with more info.
BOL
Roger
Old 10-31-2011, 12:32 PM
Rybar's Avatar
Rybar Rybar is offline
Gav, looks like you have a GTO style T56. You can probably use any of the F-body shifters like Hurst, B&M or Mcleod.
http://www.classicchevy5speed.com/Mc...ndustries.aspx
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 10-31-2011, 01:01 PM
BBPanel BBPanel is offline
I used the Red Roberts (McLeod) shifter on my GTO T56. The offset is 2" left and 2" rearward but it can go forward 2" and up to 2" either left or right from center point. I can get you a better pic if you'd like.
Old 10-31-2011, 02:31 PM
Lowfast's Avatar
Lowfast Lowfast is offline
Does it feel weird to shift not having the piviot point centered under the handle?
Old 10-31-2011, 04:06 PM
I have not driven the car yet but sitting in it and going through the gears you can't tell any differance. Very solid - if a boot was on there you wouldn't know where the center point was.
Old 10-31-2011, 04:15 PM
that looks perfect ! could you possibly get me some more info please???
maybe the measurements of the plate ?
mine is L= 5 5/8 by w= 2 7/8 aprox
also a link or where do i find these and whats this product called.. thanx !
Old 10-31-2011, 04:35 PM
Its a std f-body plate. I bought mine directly from Red (he works out of his garage to make them) but they are on McLeod's site also:
http://www.mcleodracing.com/categories/Shifters.mcl There isn't one pictured for the T56.
Just in case you don't know Red founded the company in 1971. If you call McLeod tech support Red is often there answering questions.
Should also mention his shifter does not require changing out the ball recepticle (I forgot the "correct" name for it).
